Stove & furnace for Bambi II
I need to get a stove & furnace for the Bambi II. I can get ahold of both in vintage (from a Caravel) that will fit. Owner says both are in good working order. However, would you go with the big furnace & stove top if you were redoing the whole thing, or would you get a new sleek cooktop that takes up less room & skip the furnace & get the catalytic heater that slaps on the side of the cabinet and have the space in the big cabinet for storage? Don't care if I keep it vintage on the inside, since everything will be new to it!
If I was replacing an old furnace (which I plan on doing this year), it would not be with another old one, Becky. That is an item that has the potential of causing life-endangering problems, and I'm not going to fool around.
Not only can it cause a fire if the combustion chamber leaks, but if the LP gas leaks, it can be a silent killer. Sorry to sound so morbid, but I don't find anything charming in an old furnace at all... |
Good advise, Aage. I think I'll just stick with the new idea.
Becky, with counter space at such a premium in that trailer, I think I'd go with a modern 2 burner cooktop.
I'd also take advantage of the chance to switch to an on-demand fresh water system as well, if yours is still one of the pressurized tank types. |
