-   -   Dometic Penguin stuck blower motor (https://www.airforums.com/forums/f427/dometic-penguin-stuck-blower-motor-73583.html)
tpi 01-29-2011 02:39 PM
Mine will do this from lack of use, especially when sitting long periods in wet weather.
While I'm not sure all of these air conditioners are prone to this condition, I have learned to exercise mine monthly to keep the motor free.
The solution, if stuck, is relatively easy. Try a couple quick attempts at "fan only" and don't hold the power on to a stuck motor. If a few very brief attempts fail to free the fan, go on roof, remove shroud, and spin the squirrel cage by hand.
On mine I suspect it is dirt and corrosion locking up the squirrel cage blower or the motor's armature. Once free and spun around a few times by hand, the bearing is silky smooth.
overlander63 01-29-2011 04:33 PM
You should be able to get to the squirrel cage from inside the trailer. Simply remove the 4 phillips screws holding the lower cover to the base, the cover should drop off, and you can get to the squirrel cage without climbing the roof.
tpi 01-29-2011 04:59 PM
At least on mine removing those screws didn't free the lower cover. Maybe it was the controls and wiring? Or ducting. I gave up quickly on this, because I didn't know what I was getting into.
overlander63 01-29-2011 05:39 PM
If you don't have the remote thermostat, it takes a bit more effort. I'll try to remember to snap a couple of photos for guidance, but it's still easier to unplug than climb. Especially for those of us that have trouble climbing for one reason or another.
tpi 01-29-2011 07:00 PM
Mine doesn't have the remote thermostat. So the only hangup is in removing the controls on both sides (function control and thermostat)? Mine also has the resistance heat strip. No ducting or issues like that?
Thanks.
