-   Exterior Storage Compartments & Access Doors (https://www.airforums.com/forums/f480/)
-   -   Rear storage crack and separation of trim 2008 Classic 30' (https://www.airforums.com/forums/f480/rear-storage-crack-and-separation-of-trim-2008-classic-30-a-73513.html)
SilverBeast 01-28-2011 12:50 PM
Hello Vinnie,
Novato to Santa Rosa is the nice commute! I used to get up every morning at 4am to be in SF by 8am. Iím very happy not to have to do that anymore. Now I work form my home.
I must say Iíve been remiss in not attending the Northern California rallies. Itís not for lack of interest but my work schedule just hasnít allowed for it yet.
My last big trip was to Death Valley by way of Reno. If I had known what poor shape the Donner pass is in, I probably wouldíve gone the other way through Southern California. Honestly, I thought I would lose the fillings in my teeth. It might as well be a dirt-road.
Well, Iím sure we will run into each-other one of these days!
Steve
SilverBeast 01-28-2011 12:56 PM
Yeah, I know what you mean. I think I will pull up the plastic in the back and have a good look at the wood. I don't think the molding was ever sealed properly, so water could have been going in for two or three rainy seasons completely unchecked. And you know how much it’s rained around here!
Steve
Airslide 01-28-2011 01:01 PM
These trailers are heavy and from what i can tell the frame is beefy due to the slide but there is still considerable flex by design. Cracks happen and can be resealed. Nice that its in the aluminum trim and not the actual skin. Leakage is a bigger concern. Not sure what happened at the RV dealer when it dragged bottom but stress to only one side of those drag rails will flex the body and possibly tweak those square joints of the compartment. My driveway is steep and Im always watching for drag on my way in and out for this very reason.
Let me know if you need any help with anything.. Im close by.
Vinnie
Ag&Au 01-28-2011 01:17 PM
Originally Posted by SilverBeast (Post 944004)
Hi Wabbiteer,
I understand what you mean about bottoming out the rear end. And, as I mentioned to Bob, there was an incident where this happened. It was at a dealership when they moved my trailer with a forklift. This damage could be related to that incident.
The aluminum on the bottom of the trailer looks like it’s in very good condition, it doesn’t appear to have any damage.
Thanks for your help!
Since everyone is entitled to an opinion (even me), mine is that it is 95% likely that this incident caused the damage. I bet it struck with more force on one side or the other and the resulting twisting moment on the frame caused the crack, and possible the other problem.
Ken
SilverBeast 01-28-2011 01:39 PM
I think you are right Ken. In 20/20 hind sight, I should have stayed with the trailer and not just dropped it off at the deal for three weeks.
SilverBeast 01-28-2011 01:40 PM
Thanks Vinnie!
2airishuman 01-28-2011 01:49 PM
Originally Posted by SilverBeast (Post 943423)
I have been looking at this crack grow in size, and now it looks like the trim is also separating.
the pix show cracking/splinting in the storage compartment frame metal AND welds and frame sealants.
we can't determine from the pix where it started and how it's migrated.
it also appears the acryl-r used to seal the rub rail has split.
again the CLOSE up pics are good 4 seeing this, but provide little more info...
a few larger views would be nice, might reveal more but still aren't the same as in person inspection.
...I have looked at the plywood inside the storage compartment and I don't see any dry-rot , but I could be wrong...
unless this unit was special ordered without carpet, there is carpet IN that underbed storage space.
the carpet is simply stapled at the perimeter, so it's easy to pull back for viewing.
if ordered without carpet the space will have vinyl which is also simply stapled at the perimeter.
pulling BACK whatever is there is important IF one wants to evaluate the plywood sub flooring.
the outer few inches of subfloor are 'coated' with black stuff, and somewhat more resistant to moisture contact ,
but not continuous or massive water exposure.
pull the flooring up and inspect.
...Any idea what I should do?...
lots of ideas here, but not nearly ON POINT as i read them...
-it would help to know a bit more about the issues...
like when it was first noticed and how it's progressed specifically.
the history of being moved by a forklift could be relevant, but only with more details...
((for example was it towed by a forklift or LIFTED, or scooted, entire REAR lifted or just one side and so on...))
even with a COMPLETE history and real time video of suspected event,
we (U) still might not 'know' what the degree or extend of damage resulted.
__________
frames for the slide units have structural reinforcement bits NEAR the slide and front end...
i am aware of NO difference to the frame behind the axles on these slide units...
and while the classic frames are OK, there are many of us to believe they are STILL INADEQUATE...
and that the CONNECTIONs between frame/flooring/shell are INADEQUATE.
regardless, that debate doesn't help in determining degree and extent of the issues which might exist.
____________
imo the rub rail needs to be COMPLETELY REMOVED, so that the shell/C channel/frame connections can be inspected.
rub rail removal is easy and need only extend as far as the endcap/side rivet line on each side.
1. pull the fake chrome vinyl bumper strip out of rail channel (secured with double stick stuff)
2. remove the SCREWS and cut the sealant holding the channel to the skin...
3. remove the rub rail channel from the CENTER, laterally to the edge of the end cap...
4. inspect the rivets, rivet holes and panel edging (ALL of this is under the rub rail channel)
IF the rivets are loose or moving this will be obvious, follow around both sides to find the area where it STOPS.
_________
one simply can't know IF there are any issues UNDER the rub rail, without removing it.
looking inside at the plywood is simply looking for PROLONGED water exposure, it tells us nothing about the cause...
and the hidden significant problem may not be long term enough to cause wood rot, yet.
it's possible the fake vinyl insert will surface crack and need to be replaced (easy to do)
it's possible the rub rail channel has a few rivets AND screws attaching it to the shell...
it's possible the owner is UNcomfortable attempting the removal, REinstall and any repairs needed.
and it's possible that NOTHING is weak/loose/moving/damaged under the trim...
and the cracks were caused by aliens or sun spots or superficial obamanomics...
but SOMEONE needs to dig into this deeper, before slathering goops on it.
for example the UNDER side edge of the rub rail is NOT fully sealed by intention.
this lets moisture OUT
but might also channel ANY water pooling on the bumper top, DEEP into the skin/frame connections.
a bad thing.
...What type of sealant should I use?...
this is premature until the issues are fully discovered.
repair depends on WHAT is broke'd and to what EXTENT there are problems.
the rub rail channel is simply sealed with acryl-r...
but that won't work well on gaps that are E X P A N D I N G, or larger than 2-3 mm.
polyurethane sealants like sika' 721 or parbond are used on exterior gaps with great success...
but IF the cracks/gaps are growing it will hide this for awhile,
or worse, let water in and TRAP that water.
___________
so as professor a. friend, the unknown helper,
repeats several times in the book/movie disclosure...
and JUST when the flawed hero thinks he's won...
"find/solve the problem"
cheers
2air'
dznf0g 01-28-2011 05:42 PM
It's definitely worth investigating the cause, as I stated way up the post line. But, I'm not sure the moulding is pulled away from the trailer at all. It's kind of hard to tell from the pics, but I will tell you that on the Classics, you have an extra layer of "stuff" between the moulding and the skin. The plastic and fiberglass "rolls" up vertically from the horizontal surface of the bumper top and is sandwiched between the moulding and the skin. This and the radiused nature of the top inner moulding surface makes it look like a big gap.
Then when the original sealer cracks and shrinks, as mine did, it gives the illusion of a gap. Test for tightness of the mouding. If it moves at all with moderate pressure with your fingers, then you probably have bigger issues to address.
More pics might help. BTW this rolled up lip GREATLY reduces the chances of water migrating from the top bumper surface to the flooring. The joints between the 3 bumper sections could allow a path, but it is pretty unlikely for water to migrate up about 1" to get over the rolled lip. Insert PRESSURE WASHER CAUTION HERE.
HOWEVER, water will run into that area very readily with cracked sealer on the top of the moulding. AS 2Air says, don't seal the bottom.
I would also advise, if the sealer is deteriorating here, it is elsewhere along that moulding as well. Reseal the entire perimeter of the trailer. Because (I think) the upper belt moulding is smaller and not so raduised on the upper edge, it was not as bad on my trailer. I just spot repaired the areas where the moulding had to cross over a seam where the gaps are bigger.
dznf0g 01-28-2011 06:21 PM
Originally Posted by Aage (Post 943790)
Just ordered it. Looking forward to a good laugh. Anything Lucy did was very funny.
SilverBeast 01-28-2011 07:34 PM
Thank you dznf0g and 2airishuman,
I pulled up the vinyl and there is no indication that the plywood has ever been wet. also the bumper trim is very tight and secure, so I donít think the subfloor is pulling away from the frame/skin.
Yes, It would be the best thing, to remove the trim and have a look-see. but I'm just as likely to screw something else up in the process.
To be honest, I really think the thing to do is seal it and see if it continues to open up.
But I have a bore scope, and I just might try and have a peek in one of the larger openings.
Steve
dznf0g 01-28-2011 07:40 PM
Steve
That's fine. You'll know soon enough if more work is required. Update us as your test run progresses.
2airishuman 01-28-2011 09:56 PM
do as u wish, that's the authority ownership brings...
but one simply cannot tell IF the shell/channel/frame attachment is solid,
by looking at the rub rail.
and cracks in 2 places on the door frame metal suggest that entire section of skin has moved.
________
i could link threads and photos that demonstrate this but won't,
since it seems the path 2bliss is ignoring the deeper potentials.
inspect now, repair properly and the dealer service price is a few 100$.
let it go and the costs only climb.
'it's fine' replies may be wanted, but they are simply false reassurances.
nO1ne here can offer a reliable assessment based on the 2 early pix.
so
_________
HEY i'm sure it's fine, dab a bit of goop on it...
cheers
2air'
dznf0g 01-29-2011 10:40 AM
I'm not disagreeing with anything 2Air says, I just think that exploratory surgery is not yet warranted based upon the OP's comments and pictures.
I know from prior experience that square cut welded corners on trailers are not the best of designs under even normal circumstances. Why AS gave us a square framed opening instead of radiused corners, like most other openings in the Classics is beyond me. I'm sure it has to due with cost and/or build complexity. Those square frames are very rigid and do not tolerate much flexing at all. I had issues with my prior rear entry door square cut frame SOB, immediately after purchase. I used it for another 17 years without the problem growing.
2Air is correct that there has to have been some overall rear end movement to move the opening frame off square and pop the welds.
However, IMHO, the rest of the rear end is much more tolerant of flexing that the opening frame. We're not talking about inches of flex here, to break the frame on the opening.
Since the OP has not commented on other oddities, like window frame issues, skin wrinkling, popped rivets, etc, I'm just not inclined to "over-diagnose" the situation YET.
Silverbeast, if you want further input, post some more pics of the entire rear end skin, rear windows and any other areas showing skin seams and rivets, etc. Bore scope findings, etc.
My point is NOT to ignore it, but with no other suspicious issues, if you do a reseal and there is excessive movement indicating some structural maladies, the new seal job will separate and open up rather quickly. It is just a good non-intrusive, relatively simple, inexpensive diagnostic test. Re-separation of the sealer in short order would not be normal, IMO. Proper reseal should last several years with proper materials.
JFScheck 04-02-2011 01:05 PM
Update - what was the final cause/solution/remedy?
SilverBeast 04-03-2011 01:30 AM
Still working on that.....Well, to be honest, not long after I posted this topic the rainy season really kicked into high gear here in the north bay and I had to resort to duct tape till things start to dry out.
This has been the first week of nice weather and I have not had time to rip in to the silverbeast. But, I think the first step will be to check again for any indication of water damage. Then I will get the gaps filled with the appropriate seam sealer. Then I'm installing a AirSafe Hitch on my PorPride, because I think the 1400lbs. bars I'm running are a little over kill. I have a one ton Dodge and the ride is, well lets say stiff. I don't mind and the dog is ambivalent, but I think the trailer is speaking to me.
I have a plan to see if my gut feeling is correct. It involves using the an accelerometer to test the ride inside the trailer before and after I install the AirSafe.
We shall see.
dznf0g 04-03-2011 07:19 AM
Keep us informed!
Airslide 04-03-2011 08:12 PM
We shall see.
Two things that relate. I just removed the plastic from the rear cargo area and pulled the carpet back to see what the plywood looks like back there. Overall it was in great shape. There was some water damage towards the left side. I used a product that acts like an epoxy when dry. It will strengthen the wood in the damaged area and protects it from further damage.
Secondly you will love the airsafe hitch. Make sure you get the larger one. I think its good up to 2000 lbs. The less expensive one will be maxed out with our units.
Let us know what you think.
Vinnie
SilverBeast 04-04-2011 12:22 AM
Thanks so much Vinnie! I was just getting ready to PM you about this very thing.
I saw that you talked about the AirSafe/Airride before and I wanted to get your advice. I have sent an email to Sean at ProPride to see if there is a mount available to couple to the stinger and AirSafe and also to get his advice. But I really think it's the way to go to help de-couple some of the hard knocks from our high quality pavement here in norcal.
Glad to hear that you have had go luck with the AirSafe.
I may also be picking your brain about your Hardwood floor in the future.
