-   -   Need curtain track photos circa '79 (https://www.airforums.com/forums/f39/need-curtain-track-photos-circa-79-a-73001.html)
blickcd 01-10-2011 07:15 PM
A previous owner removed the original drapes in my 1979 31' center bath trailer. They put in some roll-up blinds and valances on rods. The original side valances with upper curtain tracks were left in place, but the lower curtain tracks were removed. Front window tracks upper and lower are all in place. See the attached photo.
My plan is to buy a set of living room drapes from JPA drapes but the first step would be to get the lower tracks installed on the side windows. I think I've managed to scrounge up all the mounting hardware I need, and I know the straight track sections are avaialble.
Just so I get it right, I'd like for someone to post a few photos showing the finer details of track installation. The brackets I have could be installed in an overhand or underhand configuration and I want to get it back to factory original look. All the old bracket holes have been filled with screws so locating where they go and how many needed should not be a problem. Also some detail on how the ends of the tracks are capped off would be great. I realize photos from other model years around the same time period would probably work just as well.
The rear bedroom will be done later, but if a person has the time, I'll take a few photos of the fine details there as well. I have a full sized bed with a single roof locker on the dirver's side. The roof locker has an upper curtain track on the bottom side, while the rest of the upper track is on a padded valance that wraps around the bedroom and was left in place. All lower tracks were removed back there too.
Christopher
Rawfoodgirl3 01-11-2011 02:41 PM
4 Attachment(s)
Hi Christopher,
Here are some pictures of Wayne installing side window tracks in our '73 Safari. We were missing the bottom track on the front and side windows. JPA Drapes (Audrey...nice lady) used our final measurements to make our drapes. You could probably line up the side window tracks with your front window track.
Ellen
Inland RV Center, In 01-11-2011 02:46 PM
Christopher
All your drape track, is still available, if you wish to go that way.
Rawfoodgirl3 01-11-2011 02:50 PM
Christopher,
See how the bottom of both the side and front drapes line up.
Hope this helps you.
Ellen
noreen&sal 01-11-2011 02:57 PM
Originally Posted by Rawfoodgirl3 (Post 936675)
Hi Christopher,
Ellen
On our 81 Excella the bottom tracks line up as in Raw Food Girls fotos. Sal.
blickcd 01-11-2011 06:06 PM
Ellen, those photos are just what I needed. Thanks. Andy, I know you have the track, though no offense, I will check my local parts dealer first to avoid shipping costs, and they also give me a regular customer discount.
Anyone with some rear bedroom curtain track photos, please post them. I suspect that they are installed similar to the front, with two straight ones on the sides, and a single piece across the back with the ends bent into curves. Then again the back piece might be spliced in the middle, which makes more sense to bend up on the spot.
Christopher
