-   -   '70 Overlander Toilet Location (https://www.airforums.com/forums/f36/70-overlander-toilet-location-71271.html)
tripod58 11-04-2010 12:31 PM
I am getting ready to put my floor back in and need to make sure of the exact location of the hole for the toilet (rear bath). I had notes of it but somehow my lab got hold of my notebook and the rest is history, I think I have it pretty close from when I made my templet but just want to make sure. If anyone has the measurements from the last piece of plywood in the back or off the frame rail I would greatly appreciate it. Thanks Michael
Aage 11-04-2010 08:14 PM
Sorry, I am not catching something here:
If you have NOT YET put in the floor, all you need to know is that the toilet sits directly on the flange that you will screw into the black tank.
That should be obvious with no floor present...? :blink:
tripod58 11-04-2010 08:29 PM
I dont have the original black tank, as I am adding a gray tank.. I got it figured out though. thanks anyway
WILDRTEXAS 11-04-2010 08:48 PM
Dude, Seriously???
68 TWind 11-05-2010 05:45 AM
I would strongly suggest that you put your floor in first before you cut the hole. Then, put your fixtures in place in the bath so you can position the toilet exactly where it needs to be. Step on the flush valve and make a mark on the new floor in the dead center of the hole in the toilet. Cut the hole in the floor and be careful to get in just large enough for the flange to fit so it will be tight. Then, put the new black tank in from the bottom, get it exactly where it needs to be and mark the top of the black tank through the hole in the floor and then the fitting on your new tank will be in the right position. This will assure you 1) have the toilet where it needs to be inside the bathroom, in my TW it was very tight 2) the hole and flange in the black tank will be positioned exactly. Had I used the measurements from my old black tank or the old floor the new toilet would not have been located properly.
