-   -   Frame Damage under battery compartment (https://www.airforums.com/forums/f36/frame-damage-under-battery-compartment-70891.html)
Bill M. 10-24-2010 11:31 AM
Bought a 1988 Excella that looks good. Except, when I checked out the rust where the left front frame member enters the trailer under the battery compartment. The frame is rusted through at the bottom and one side.
How can this be repaired? My thought is that maybe a local welding shop could cut out the damaged part and weld back in a new tube. Or perhaps weld supports along the side and bottom?
Can they weld to it with the wooden floor above, or what???
Perplexed and a little unhappy.
Bill
62bam 10-24-2010 12:39 PM
Andy......we need YOU!
Bill M. 11-16-2010 11:14 AM
Not a lot of help on this one do I see. So I get to update my own post. I rigged up a brace for the really rusty area out of channel iron and ubolts and towed the rig to Jackson Center. Repar is going to consist of replacing the whole A assembly and some work on one frame member.
When you buy an Airstream, be sure to check out this area better than I did. Or budget an extra three grand and a couple of tows to and from Jackson Center in case you make a mistake. It looked rusty, but the original paint and caulking to the banna skirt hid the deeper damage. I pried out the caulk and started to scrape it to paint and a whole sheet of the surface of the frame with the paint attched fell off revealing the rust through the frame. It was also very rusty under the front belly pan. Main frames looked okay.
We had the option of fixing it right or bracing it up and using it as a park model. We like it well enough to go ahead and get it repaired. Had a broken fresh water tank also. I am now well over budget for repairs. I would like to be able to weekend with it even though it will be parked on a lot in Fl most of the year.
Inland RV Center, In 11-16-2010 11:22 AM
Your question?
Inland RV Center, In 11-16-2010 11:23 AM
You did good by having Jackson Center do the repair.
Just saw your post.
