-   Land Yacht/Legacy Motorhomes (https://www.airforums.com/forums/f312/)
-   -   small compressor (https://www.airforums.com/forums/f312/small-compressor-69925.html)
YACHTSTER 09-26-2010 07:07 PM
small compressor
94 ly diesel i wonder about the small compressor in the front trunk. should it shut off at a set pressure? all laws of mechanics tell me so does anyone know for sure or should i hunt a leak?
BarnacleBill 09-27-2010 07:54 AM
What is the compressor for? Does it run continuously?
HowieE 09-27-2010 08:37 AM
Yes any compressor should have a high limit switch that shuts it off at a set pressure.
Now if it is running without shutting off it could be a leak on the high side, poor compression, worn out, within the compressor, or a bad shut off switch.
I would suspect on of the first 2 since a bad limit switch would cause excess pressure and should pop off the safety valve on the reserve tank.
