vent fan dimmer switch
I have a 68 Sovereign. One of the vent fans was not working, I removed the switch and found that it was broken; the wire from the coil to the terminal was broken and the hot lead terminal itself had snapped apart.
I know it is 12 volt DC, maybe around 4 amps. What I cannot seem to do - after 45 minutes of searching these threads and going to many online parts places for Airstream, as well as calling auto parts stores, my 2 local RV dealers, and a marine store - again, what I cannot seem to do is find a replacement switch! Please - sell me or tell me where I can get a switch... sorry to be so desparate - but my local rv dealer told me to go to home depot and get a regular dimmer! I am no electrician - but that is plain dumb! Thank you, Jim |
Is it an original vent fan or a fantasic fan
You will also need a resistor so that you can select either full or partial speed. A regular dimmer, your correct, is dumb. Andy |
it is original.
Thank you Andy - always great info! |
The ceiling fans in Airstreams since 1965, all run on DC. That's why a fixed 10 watt wire wound resistor is used for speed control. Andy |
