-   -   what material to use for interior walls (https://www.airforums.com/forums/f39/what-material-to-use-for-interior-walls-68331.html)
jemma 08-18-2010 11:21 AM
We are adding a partition inside our 75 Argosy and don't know what material to use. Any help would be appreciated.
Jemma
adwriter73 08-18-2010 01:10 PM
What about acrylic for a more modern look? 1/4 plywood material painted, laminated, stained or wallpapered may be the standard option.
kennethowens 08-18-2010 01:33 PM
partition.....
An easily mounted "curtain" is quickly setup and taken down. It does
not add much weight or require alot of hardware either. Often, the simpler
the better.
