-   -   leak at toilet base (https://www.airforums.com/forums/f446/leak-at-toilet-base-6740.html)
bbwwjd 09-15-2003 09:47 PM
leak at toilet base
While camping over the weekend ,we noticed a bit of water around the toilet base in our '69 OL Int. What would be the most likely source?Pressure water in,or flush water going out?Thanks,Len
Happycampers 09-16-2003 04:16 AM
toilet leak
Hello .. we had the same problem with our 1976 tradewind.. the water just leaked occasionally.. the rv place said it was the ball valve and it has been replaced.. haven't had the chance to check it out but will before the end of the month.. Annie 1976
drboyd 09-16-2003 01:33 PM
You could put a couple of drops of food coloring in half a bowl full of water, and figure it out in a minute.
So, it depends. If it's "used" water (to put it gently), it's probably the gasket between the toilet base and the tank. Actually, there are a couple of gaskets that could leak and mess you up. Replacement gaskets are available at your friendly RV dealer, but there are two different kinds of Thetfords, before 1985 and after 1985, so you'll basically need to take the toilet off and apart before you go get the new gaskets.
If it's "first time through" water, there are different options. Either the water inlet valve is leaking, or the internal vinyl hoses have basically died on you.
Mine was leaking clean water, and it turned out to be the hoses. You'll need about 6 feet of vinyl tubing and a pair of hose clamp pliers like these.
Don't even think about doing it without the pliers - trust me on this!
Don
KLK 11-10-2019 03:21 PM
I’m glad I found your response.
Will you please tell me where the “water inlet valve” is?
I need to repair this (among other things).
Thank you.
Kim Koogle
