-   Exterior Storage Compartments & Access Doors (https://www.airforums.com/forums/f480/)
-   -   Outside storage latch corrosion (https://www.airforums.com/forums/f480/outside-storage-latch-corrosion-67205.html)
Oasf60 01-18-2021 11:32 PM
Just want to confirm the McMaster part 1590A45 is still good. Replaced all my latches with stainless and they look great.
Bgarhammer 01-19-2021 04:40 AM
I use a generous amount of ACF-50 on my Airstream on any parts which I feel may be affected by corrosion.
ACF-50 has a kit that is $30 from Aircraft Spruce or available on Amazon. I comes with a small spray bottle and a re-fill bottle.
It is viscous enough to remain on the surface until the next cleaning. It has also a purple hue, so it combines well with aluminum and stainless steel.
So far, it has proved to be a means of reducing corrosion and rust. I actually had the rear storage area, axles and the entire bottom of my unit treated with Corrosion X when I bought it.
I have the fortunate ability to store my unit indoors and since corrosion is a function of electrolysis, I also ground my unit.
Thorasaurus 04-27-2021 02:36 PM
The McMaster latches are still available and look great. I had to buy some stainless rivets to install them, but it was a worthwhile upgrade for my old rusty latches. Thanks for the recommendation!
