-   -   measuring floor (https://www.airforums.com/forums/f36/measuring-floor-66998.html)
bwaysteve 07-17-2010 09:00 AM
measuring floor
Floor gone soI have no template for rear floor.I am in the process of cutting a piece of thin luan for a rear floor pattern for tank hole etc..
I have measured 87 1/2x 48in. across the frame.How do I take the measurement for the curves on both sides?
NJtoNC 07-17-2010 10:02 AM
i would take a piece of big brown paper, lay it out and use your fingers to push the paper into the curve of the trailer and then trace the 'dent' in the paper. trim the paper,go back and fill in w/ more paper or trim where it needs to be trimmed and then lay it out on the luan.
vswingfield 07-17-2010 11:36 AM
Using the paper pattern technique above, get is close to the right fit. Then place it in the trailer and scoot it as close to the back as possible. Then take a compass (for drawing circles, point on one end and pencil on the other) and hold it with the point against the rear wall keeping it (the compass) parallel to the length of the trailer. Follow the rear will with the point and the pencil will make an exact copy of the wall offset onto your luan. You can then trim this to a perfect fit. It's the same technique used for fitting counter tops to walls in homes.
Using the luan for pattern making is a good idea, too.
bwaysteve 07-17-2010 12:56 PM
Great
Great,Now if I can find all my school supplies from 3rd grade for a compass.I did the paper and got almost perfect.Now is the curve in front same as the back?The luan is great as it just slides in.I can then mark all my holes for BT and transfer to 3/4.Thanks
InsideOut 07-17-2010 01:07 PM
We found all four "corners" of ours to be different~
Shari :flowers:
utee94 07-17-2010 01:16 PM
Shari :flowers:
Absolutely, they are not identical.
