-   Buyer Guidelines (https://www.airforums.com/forums/f353/)
-   -   Top 5 issues at delivery (https://www.airforums.com/forums/f353/top-5-issues-at-delivery-65186.html)
gamana 06-01-2010 09:26 PM
I will be taking delivery of a new International 27FB next week. This is my first Airstream/RV and naturally, I am a bit nervous to perform the "walk through" with the dealer.
Recent purchasers of Airstreams, could you let me know what were your top 5 issues/defects you discovered.
Cheers
Aage 06-01-2010 09:33 PM
If you don't hear "leaks" in that list, I will be really surprised...
kidsgone 06-01-2010 10:00 PM
LEAKS!!!! We have a new Int. 27 FB and all, yes all, of our outside compartments seals were improperly installed and we had a flood (not a leak, a flood). Our dealer fixed them asap, then had window and vent leaks. But all was taken care of and now we are travelling all over.
Highly recommend video taping the walk thru....we have watched our tape many times to answer many questions! Also, make sure the awning works properly. let them show you how to operate it, then do it yourself with no help from dealer. Also, get on top and look at seals!! We have had problems with the new 3m seals for the vents, check those carefully. Also, the microwave will not pop popcorn!! I went straight to the manufacturer on this one, and they said nope, will not pop popcorn...
Again, videotape, videotape, videotape! We have reviewed it sooo many times. And read the owners manuals before you go anywhere...we had alarms going off one night and went scrambling for the books at 3am! We can laugh at it now....
Enjoy your adventure, we love our International named "Belle".
See you on the road....
sempi2 06-01-2010 10:37 PM
A microwave that won't pop popcorn, really?? What does it do then?
TBRich 06-01-2010 10:47 PM
:huh: How sad is that! Never heard of such a thing. Even our little cheap microwave that we take with us sometimes will pop popcorn!
Jammer 06-01-2010 10:58 PM
Well, sample size of one, here's what I found, not in the walk through but on the first couple of trips:
1) Loose trim on kitchen cupboard
2) Rear A/C temperature sensor not connected
3) Half of oven burner won't light from pilot, has to be lit by hand
4) Stovetop washer/grommets defective, won't hold up the weight of a pan
5) Locks required graphite lubrication to allow keys to work smoothly
6) Sensor for sewage tank shows empty all the time (sensor problems are, apparently, common)
7) Missing screw in one of the panels in the bathroom
8) Bad ballast in one of the fluorescent lights
9) Freshwater system leaks back into the tank, probably leaky valve in the pump
10) Defective latch on one of the cabinets
11) Coat closet door mounted too high, hits A/C ductwork
12) Loose socket in triarm light over dinette. Bulb won't stay seated
13) Several loose counter items, faucet, soap dispensers
14) Holes in A/C filters because someone put a screw in the wrong place
15) Excessive noise from rear A/C
I didn't take the walkthrough seriously because I figured I was going to have to bring the rig back to the dealer in the first couple of months anyway and it wasn't worth it to me to rake them over the coals on delivery day. Ymmv.
As for the microwave, I thought they were just for melting chocolate and butter.
wheel interested 06-01-2010 10:59 PM
Upon walk through, you may find things like uneven trim and other cosmetic issues or awning adjustment that they will take care of before you leave the dealership. Take your time, enjoy and spend a night or two nearby and return for any issues that are found later. There is much too much to inspect at once. The waranty is well stood by and you will be served well by a good dealer or the factory. Troubles with battery recharging, shower leaks, doors and alignment may be the worst you encounter. Sometimes the window locks need adjustment. Open and close the fantastic vents. They often stick and need either trimming or 303 to condition the weather stripping and open more easily. Inspect the outside around the spotlight and tail lights and door handle and battery compartments for corrosion. They can replace or fix the clear coat. You will have to open all the windows and burn off the new manufacturing oils etc., with the oven and heater. Congratulations. We want pictures!!:)
Bluto 06-02-2010 10:09 AM
At the delivery time: Received new light fixture as one reading light was defective.
I had a good service person do the walk thru with us and it went smoothly. Apparently he had some training from Airstream. He answered all my questions during the walk thru. After I came home I had some time to read the manual and handouts from the various manufactures and I had a few more questions. He answered them over the phone.
Airstream also accepts emails to the service dept and will answer any additional questions on line if you want to go that route.
It was a good experience for me!
I bought one off the lot the first time and had many issues with broken things that were just flatly abused from people going thru the trailer at the dealership.
vswingfield 06-02-2010 10:27 AM
Even more important, what kind (brand and model) of microwave is this? Help warn others.
End of my hijacking.
Since I bought both mine very well used, my list hardly applies.
Enjoy your new International, gamana!
jcanavera 06-02-2010 10:33 AM
Probably the #1 issue has been leaks from the shower door area. My 2001 Safari and 2004 Classic both suffered from this malady. It seems to be something that may take multiple visits to finally control. It has something to do with the door framing that seems to be prone to improper sealing during installation.
My only other issue is the failure of a check valve in the fresh water pump requiring it's replacement. I have replaced the sensor control panel due to a burnt out LED.
My local dealer has hookup spots at the dealership and encourages owners to spend the first night there. This way it gives you time to go through the walk through and the next day, get any issues taken care of prior to you driving off.
My advice to watch carefully the awning set up and storage procedure. Also, if you are new to trailering, pay special attention to the hitching procedure.
Jack
gamana 06-02-2010 06:09 PM
Thank you all for your inputs. It seems like the most important issue I need to look for is leakage which is not so easy to determine within a couple of hours on the parking lot of a dealer.
Has anyone ever asked a dealer permission to water the roof of an AS with a hose pipe for 15-30 mins???
kidsgone 06-02-2010 06:58 PM
Gamana, We did ask our dealer for a water check after the leaks were fixed and they complied....no problem.
As for the make of our microwave...Tappan. We took it to a Tappan dealer and they said that our model would not pop even a small bag of popcorn....we thought it was defective that's why we took it to them. They wouldn't do anything...we need to replace it soon....I need my popcorn!
gamana 06-02-2010 08:02 PM
Kidsgone, thanks for the info on the water check.
Since it is my own post I can probably hijack it for a couple posts ;).
Why do you need a microwave to make pop corn??? I have always used a pot with a lid!
Aquabud 06-02-2010 08:27 PM
I took delivery of a new 27FB International last month. Still have not "tripped" in it yet. I did drive it home...3 hour drive in a pouring rain. Didn't find any leaks. I washed it down pretty good the next day from the top down and didn't discover any leaks whatsoever. Not sure about the shower yet.
My dealer, Woodland RV in Grand Rapids, Michigan, did a fantastic job of prepping our unit. Had a very thorough walk-thru. I really think they did a lot of adjustments prior to our picking up the unit that was ordered. They had the unit for about 3 weeks before I picked it up. No problems yet...but...we have not yet tripped in her.
I'll be keeping my fingers crossed.
Enjoy your AS. They are great.
jcanavera 06-02-2010 08:42 PM
I know my dealer washed and Walbernized my trailer prior me arriving. So far with two new trailers, I've not had external leaks that were evident upon delivery. I have had two skylight leaks. One under warranty and one outside of warranty. The one under warranty showed up in year two of ownership and required the skylight to be removed and reinstalled and sealed. The one on my nickel was a crack that most likely caused by overstressing a screw during the building of the trailer. The crack didn't appear until the trailer was 3 years old. On that one we replaced the skylight.
The shower door leaks we found the following morning since we overnighted with a full hookup at the dealership and used the shower that morning. Unfortunately any other leak may not show up with the roof getting wet from a hose. Some water leaks may only show with wind driven rain or when the trailer is in motion, others may take a long amount of rain. My guess is that a 15-30 minute watering of the roof may technically show nothing. You really can't simulate hitting a trailer with rain by using a hose. In addition, leaks can travel some distance and the source may be far away from where the leak shows up.
Jack
Gene 06-02-2010 11:35 PM
Make a list so you don't forget anything. The dealers schedule 2 hours, but I asked for more time and got it. Ask ahead of time so they can accommodate you.
My dealer did a sloppy job of setting up the hitch. After I figured that out and did it myself months later, the trailer towed better. Some dealers don't want to take the time to do it properly because it cuts into profit. Make sure your tow vehicle is level and the trailer is level before you leave the lot. Make sure they put the right size weight distributing hitch on as they may just install whatever size they have. Some dealers habitually overhitch.
We had a window blow out a 100 miles from the dealer. The latches were not adjusted properly. The dealer is supposed to do a thorough check of these things and I believe the factory pays them for this.
Sometimes these things set on a lot for a long time and the batteries get run down too far and don't last long after you take it home. Have them check the cells for how good they are.
Testing everything and hearing everything when you pick up the trailer is overwhelming. Videotaping is a good idea. Read as much as you can beforehand so you know what to look for. Stay at a campground nearby for a few days and check everything over and over so you can take it back for repairs. We had several immediately obvious things the next morning and many more in the months ahead.
Some dealers do a good job, but some do not. I hope the best for you.
Gene
wheel interested 06-03-2010 12:52 AM
Try an upside down plate in the microwave and put the bag on top of that. That's what our low wattage microwave suggested. It worked. Can't think if why yours doesn't pop corn.:huh:
Aage 06-04-2010 12:54 PM
If it will boil water, it will pop corn.
if it won't boil water, well, time to get a different microwave.
Antique Pedaler 06-04-2010 01:54 PM
Spend the first night on the dealer's lot and pray for rain. In addition to checking for leaks, use everything in the trailer. Don't leave the the dealer until everything is to your satisfaction.
bob34787 06-04-2010 03:32 PM
well if you are picking it up at dealer near tampa (who shall remain nameless) I would suggest making them open all windows, show you how to work everything, look for loose trim everywhere, make them clean it, including the interior aluminum and if they are doing your hitch work, go somewhere and have it re-done
