-   -   Carrier AC Unit Drain Hole (https://www.airforums.com/forums/f427/carrier-ac-unit-drain-hole-64566.html)
jhonken 05-15-2010 10:05 PM
I am in the process of installing a new Carrier 13.5 "non" low profile AC unit in my 1973 Safari. I have seen threads on the forum that you can drill a hole in the pan of the sling wheel and use the existing drain tube. Does anyone have pictures of where they drilled this hole? I thought I actually saw a video of someone doing this on the internet but I cant find it again or maybe I was hopefully wishing. If anyone could point me to a picture of how this was drilled I would greatly appreciate it.
Inland RV Center, In 05-16-2010 02:04 AM
The hole is drilled at the bottom of the collector pan.
That's the easy part.
You then must install a connector, so that you can attach the drain hose. Not easily done because of the lack of space.
However, I would suggest you leave it alone, as very rarely will any water overflow onto the shell.
GREENovaters 08-22-2010 09:33 AM
What happens if there is no collector pan to drill a hole into under the sling wheel? Does anyone know where to get one?
