-   Land Yacht/Legacy Motorhomes (https://www.airforums.com/forums/f312/)
-   -   Cummins B5.9L 230 HP Turbo Diesel w/Allison MD-3060 6-speed transmission (https://www.airforums.com/forums/f312/cummins-b5-9l-230-hp-turbo-diesel-w-allison-md-3060-6-speed-transmission-63683.html)
1995LY 04-20-2010 01:34 PM
Hi I recently purchase a 1995 35í land yacht wide body pusher. I am missing some type of overflow plug on the housing between the Cummins Diesel engine and the Allison transmission. I believe it is the torque converter cover.
Itís a large treaded bolt whole right on the bottom of this housing less than 1". Does anyone know what this is, my oil levels are all good (trans and Diesel) thatís why I think itís an overflow of some type.
Thank you.
GCinSC2 04-20-2010 07:05 PM
Jim,
I could easily be wrong, no experience with your combination. But the Cummins 5.9L used in Dodge applications has 2 holes in the engine to transmission adaptor housing below the turbo one is used for access to the torque convertor bolts and the other allows you to insert a BARRING tool into the housing that allows the engine to be turned over using the tool for valve adjustments and timing work and any other reason to slowly rotate the engine for service.
ENGINE OFF! Look into the hole and see if you feel the flexplate and try to rotate the engine by hand and see if a bolt appears. If you feel the ring gear, then I'd bet it's the BARRING tool hole.
No guarntees.
1995LY 04-20-2010 08:34 PM
Photo Attached
Thanks GC, i took another look and it appears to be part of the Cummins Diesel housing - because of the color (paint). I still believe it's the shroud over the Torque converter. I also attached a photo which may help.
GCinSC2 04-21-2010 06:43 AM
5.9L Barring Tool Hole
I'm sorry, I do not know what your plug hole is for. The pic will definetly help someone identify it.
1995LY 05-10-2010 11:06 AM
Follow up
3/4" black pipe plug fit perfect.
YACHTSTER 10-19-2010 12:25 PM
mine looks the same no plug, did you put pipe plug
uism 10-19-2010 05:24 PM
On my 95 classic It is were I see the rear engine seal leak not bad yet. 1qt every 5000
mi IKE
TBSarfari28 10-19-2010 05:58 PM
Most all mid-range and heavy-duty diesel engines have the same type of hole in the flywheel housing. The hole is never plugged, it can be used on many engines to bar over the engine by using a screw driver through the hole by prying on the flywheel ring gear teeth. As mentioned before it can be used to tell when your rear crankshaft seal is leaking and the transmission input seal also.
Tom
