-   Winterizing, Storage, Carports & Covers (https://www.airforums.com/forums/f458/)
-   -   Winterizing Compressor Question (https://www.airforums.com/forums/f458/winterizing-compressor-question-57185.html)
Airstream 65 10-06-2009 03:45 PM
I'm thinking of getting one of these two DeWalt air compressors for blowing out the lines in our 65 Overlander and 09 International.
DEWALT D55168 : 1.8 HP Continuous, 200 PSI, 15 Gallon Workshop Compressor
DEWALT D55167 : 1.5 HP Continuous, 200 PSI, 15 Gallon Workshop Compressor
Would either one of these be able to do the job?
Thanks.
Minno 10-06-2009 04:42 PM
Yup - either one would work, the smaller one would be just fine. You could get by with an even smaller one if that's all you're buying it for. 4.5 SCFM at 100 PSI is more than enough air flow. You probably only want it set to about 40 PSI for blowing out the lines.
Chris
Airstream 65 10-06-2009 07:48 PM
Ok, thanks for the input. I'll give one of these a try.
