-   -   1965 Airstream Safari CB Antenna (https://www.airforums.com/forums/f4/1965-airstream-safari-cb-antenna-56485.html)
classicshow 09-17-2009 06:24 PM
Hello all,
i have a 65 safari and it has the CB Antenna ball connector but it is missing the Antenna whip would anyone know the correct size for my model? I found a 102" CB Whip from Radio Shack that might be the one but i want to make sure.
Thanks;)
overlander64 09-17-2009 06:39 PM
Greetings classicshow!
Welcome to the world of Vintate Airstream ownership!
Originally Posted by classicshow (Post 749072)
Hello all,
Thanks;)
You have found the part that I used on my '64 Overlander. You will likely find that you have a clip to retain the whip in a "lowered" position for travel at the rear edge of the streetside front window.
Good luck with your coach!
Kevin
