-   -   Best fix for holes from lock hasp (https://www.airforums.com/forums/f4/best-fix-for-holes-from-lock-hasp-53440.html)
68 TWind 07-05-2009 05:57 PM
Need advise on ways to fix the holes left after I removed the riv-nuts where a PO had installed a "deer camp special" (hasp for a padlock). I have 2 holes on the door and 4 on the body of the A/S. I have some 2024 sheeting and thought about making a patch panel and using counter sunk aircraft rivets. I have the interior skin loose around the door to replace the floor so I have access to buck the rivets. I also thought there might be a easier way, I just haven't thought about. The holes are a little bigger than the head of an Olympic rivet.
Thanks in advance for ideas.
moosetags 07-05-2009 07:04 PM
I would consider filling the holes with some high quality stainless machine screws of an appropriate size.
Brian
Inland RV Center, In 07-05-2009 07:19 PM
I wouls suggest ice looking plates, since you already know the rivet routine.
Seal the holes with Vulkem, before you plate the area.
Lumatic 07-05-2009 08:57 PM
Add a patch of aluminum with Olympic Rivets which will blend right in with the originals
