-   Our Community (https://www.airforums.com/forums/f48/)
-   -   Airstream steel wheels (https://www.airforums.com/forums/f48/airstream-steel-wheels-510.html)
davidz71 05-21-2002 06:16 PM
Just wanted to let you know that 4 Airstream grey steel wheels are on ebay right now, pg. 2.
thenewkid64 05-21-2002 08:02 PM
here is a link
This link will take you to the above mentioned wheels.
https://cgi.ebay.com/ebaymotors/ws/eB...ndexURL=0&rd=1
tenrsingr 05-21-2002 10:03 PM
Will my hubcaps fit on those??? Hmmm... I have the original Hubcaps and would not be happy if they didnt. Anyway....
I am sure someone knows the answer here...
Thanks in advance...
davidz71 05-22-2002 11:14 AM
Thanks Brett,
I wasn't sure how to post that link so thanks for sending folks to it. Craig
Action 05-22-2002 11:32 AM
E-Bay wheels
Those wheels are "wagon" type wheels and require no hub cap. Maybe a hub center, not a hub cap or wheel cover. The hub center would cover the very end of the axle. And the hub centers that I have seen in the past are chrome over plastic. Earlier versions were chrome over metal.
Or the wheels in question can be used with no other pieces. I have the same wheels on a boat trailer and at the end of the axles are fittings that allow me to grease the hub with a grease gun.
>>>>>>>>Action
apple 1 05-23-2002 08:50 AM
The Airstream wagon wheels use a chrome center to cover the axle end and a chrome trim ring for the outer edge. The trim ring is about 2 1/2 " wide. I have had to replace two of these wheels because of cracking on my '96 30' Excella and they go for about $75.00 each, without the trim parts, from Airstream. They do look good on the trailer with the trim installed.
