-   1970 - 1973 Sovereign (https://www.airforums.com/forums/f186/)
-   -   Little Girl Refurb 1972 (https://www.airforums.com/forums/f186/little-girl-refurb-1972-a-50967.html)
wasagachris 05-19-2011 04:57 PM
Hi MC is that one of those paints that goes on blue and dries white or is that the color you're using?
I see that the center piece is missing. Will you be putting it in later or do you have some sort of master plan involving something radical? Do you want to let us in on the secret plan?
Looks fantastic by the way.
Minno 05-19-2011 05:17 PM
Hi WC. The ceiling center piece is off right now for any extra wiring we might need to do (or, rather, HE needs to do - me wiring would be a scary proposition, at best). It's blue paint. We primed with white Bondz exterior primer, and are using Dutchboy Maxbond exterior paint satin for the finish color. And the name of the paint color really is "Pursuit of Happiness".
We've been toying with other ceiling finishes besides putting the center piece back up, but haven't made any decisions yet. Probably will end up with the regular ceiling piece.
Kay
wasagachris 05-19-2011 05:24 PM
Knowing Chris's penchant for doing extreme work I thought he might have had some grand design change like a mirrored ceiling or some thing with fiber optic lighting.
A limo shop I worked at installed hundreds of small fiber optics in the ceiling which was illuminated using a revolving color wheel. The end result was hundreds of little sprinkles of light that were constantly changing color. That would be cool to look at. Hint Hint.
Minno 05-19-2011 07:28 PM
Oh, please don't encourage him! Actually, I'm the one going for something different like maybe pressed tin. I also saw in one of the Airstream mags a year or so ago, an AS that had woven cane for the center ceiling panel. The sides were done in wood veneers, and the effect was wonderful! I think it was an Adairondak redo... HMMMM, maybe a nautical theme since we're painting blue and have fish swimming in a tank in the ceiling.... we could thin out the herd in the pond since they're spawning again...
sprinkles of white light would go with the quilt - the name of the pattern is Celestial Puzzle...
Hm, Hm... don't want to get a woman thinking too much, you know!
Kay :p
72BamaStream 05-20-2011 07:29 AM
wow...
Hey Chris and Kay!
It's your long-lost Southern girls down in Mobeeeeeeel!!!! We are so behind in following all of your work but, do know, over the last year and a half Tina and I have thought of you guys often and we will definitely be running through all the pictures and descriptions I KNOW y'all have posted during the process (so thorough you both are... it's great :wally:)... I opened my own business last year so it's been a little time-consuming, to say the least:)
LITTLE GIRL is looking fantastic!!! She's growing up so fast :)
Happy Summertime... I hope you two are well... no, better than "well"... I hope you two are FANTABULOUS!
Shar
mello mike 05-20-2011 08:21 AM
Lookin' good, Chris and Kay!
chowman2011 05-20-2011 09:51 AM
Great Work and coverage of Your(Chris and Kay) Progress!!!
I've enjoyed this post ALOT!
Need to get back to My "Refurbish"....
Cheers,
Christopher
Minno 05-20-2011 03:39 PM
WC - Fiber Optics, huh? Intriguing.... color and pattern possibilities boggle the mind! :blink:
Shar!!!! And Tina!!! Great to hear from you two again! Weíve thought about both of you often as well, and wondered how you were doing. New business, huh? Iíll bet thatís keeping you hopping. But I hope you still find time to get out camping and enjoy yourselves. Happy summertime to both of you too! :flowers:
Mike & Christopher Ė thanks!
Feels great to be making some progress again. Rainy this weekend, and Kayís off on a quilt retreat, so Iím here to fend for myself. Maybe Iíll go buy some fiber optic cable and so some experimenting. But most likely, Iíll work on priming, painting, and get back to the black and gray tanks.
MC
wasagachris 05-20-2011 04:02 PM
Hi MC the fiber optic cables were almost microscopic in size. IIRC the drill bit size was 1/32" or maybe 1/64" and then the ends of the cables were hot glued to a sheet of lexan that was mirrored. The efffect was like twinkling stars. The light generator box was about 4" square,running off 12VDC with a rotating 5 color wheel. Due to the arrangement of the fiber optic cables in the box the color change would sweep across the roof. It was really cool to look at.
Minno 05-22-2011 09:34 AM
Sounds like a great idea for a limo. :cool: Probably not so much for a airstream... MC
Minno 05-22-2011 09:48 AM
6 Attachment(s)
In addition to painting (second coat is on the rear half of her now), I've been working on the tanks. Biggest accomplishment on that project yesterday was gluing the 3" drain fitting onto the black tank.
Attachment 130405Attachment 130406
Hole cut at bottom of tank on the forward facing side.
Attachment 130407
Here I'm set up to bend the flange on the fitting a bit, so it will fit tight to the curved bottom of the tank.
Attachment 130408
Flange bent to fit tank.
Attachment 130409Attachment 130410
Fitting glued in place.
Today, I'm mixing up some more ABS slurry to fill in all the nooks and crannies in the inside to ensure nothing gets caught while draining. Also extra precaution against leaking.
On the painting project, I made a new vista view blind out of sheet aluminum. (One blind was missing.) All 3 blinds are now painted on both sides (second coat is drying). I also made new blind handles out of red alder, and they have 3 coats of finish on them (3rd coat is drying). I'll post pictures of them after I get the handles installed.
Chris
Minno 05-22-2011 08:37 PM
Vista view blinds:
Attachment 130457
Here they are, all painted with the new handles installed. Hard to tell in the picture, but they are the same blue we're painting the interior. I used super glue to glue the edge trim on each side. These edge pieces ride in the channels that the blinds go up and down in.
Attachment 130458
Here's the first blind in place. I discovered that the top of the opening was not square to the blind. Not sure why, but it must have always been that way since the bottom and sides of the opening are square. Anyway, I cut it square before riveting the skins in place.
Attachment 130459
Here's a more or less final picture of the blind in place with the edge trim installed. The edge trim looks really bad, and it doesn't fit the opening very well, so I think I'll replace it.
Now to install the other two blinds and finish riveting the skins back in place. Then we can prime and paint the front half of her.
Chris
Minno 05-29-2011 07:58 PM
7 Attachment(s)
Yesterday, I installed the two vista view blinds on the starboard side, and then we finished riveting the front head liner and inner skins in place. Then we primed, and got one coat of paint on her. Today, we did the second coat of paint on the front half.
Attachment 131043Attachment 131044
Attachment 131045Attachment 131046
Hereís a before pic, a primed pic, and an after pic, along with a closer pic of the vista view blinds.
With the painting done for now, we can focus on the other projects. In addition to the tanks, Iím now starting to work on the electric panel installation.
Attachment 131047
Hereís the panel weíre using, complete with the charger in the bottom. One 30 amp breaker for the main, one 15 amp breaker for the charger, and six 20 amp breakers for everything else.
Attachment 131048Attachment 131049
Eventually, there will be a cabinet built that will house the panel. It will be directly aft of the fridge. This evening, I got the breakers and the 12 volt side ground bus installed, as well as the 110 VAC input from the shore power connector and two of the 110 VAC circuits connected.
Chris
Top 05-29-2011 08:13 PM
Quality work. As always. The blue makes the inside seem much bigger. Nice.
ddstech 05-30-2011 11:55 PM
<img src="https://www.airforums.com/forums/attachment.php?attachmentid=131043"/><img src="https://www.airforums.com/forums/attachment.php?attachmentid=131044"/>
<img src="https://www.airforums.com/forums/attachment.php?attachmentid=131045"/><img src="https://www.airforums.com/forums/attachment.php?attachmentid=131046"/>
Here’s a before pic, a primed pic, and an after pic, along with a closer pic of the vista view blinds.
With the painting done for now, we can focus on the other projects. In addition to the tanks, I’m now starting to work on the electric panel installation.
<img src="https://www.airforums.com/forums/attachment.php?attachmentid=131047"/>
Here’s the panel we’re using, complete with the charger in the bottom. One 30 amp breaker for the main, one 15 amp breaker for the charger, and six 20 amp breakers for everything else.
<img src="https://www.airforums.com/forums/attachment.php?attachmentid=131048"/><img src="https://www.airforums.com/forums/attachment.php?attachmentid=131049"/>
Chris
Looks great, really great. What paint did you end up using? Just curious.
Minno 05-31-2011 07:58 PM
Hey ddstech - we used Bondz exterior primer and Dutchboy Maxbond satin exterior paint for the top coat. The paint color is "Pursuit of Happiness".
I did get more wiring done Monday & this evening. The 12 VDC circuit wires are connected to the panel, as are the rest of the 110 VAC circuits. I also connected the battery we've been using to power the roof vents, so the charger has something to do. Right now, two 12 VDC circuts are being used (one to each roof vent fan), and I have four 110 VAC outlets wired in. Plus the roof a/c is connected. Now I can plug things in and get rid of the extension cords we've been using. :)
Chris
Minno 07-23-2011 06:34 PM
4 Attachment(s)
Finally made time to work on her again! Worked on Kayden's crib this morning, but this afternoon was spent doing floors in Little Girl.
Attachment 135661Attachment 135662
Attachment 135663
We installed the bathroom floor, which is sheet vinyl over 1/4" luan plywood subfloor. The plywood is more to bring it up closer to the height of the other floor than anything else. It's glued and perimeter screwed to the plywood subfloor, and then the vinyl is glued on top of it. The missing corner of the vinyl is where the old battery box was located. I'm going to reinstall that box to use as a small exterior storage compartment.
Attachment 135664
After the bathroom floor, we started tackling the rest of the floor. Its engineered cork, 1 by 3 foot tiles that click-lock together. It came with an underlayment; which is the gray stuff you see in the picture. This is as far as we got before we ran out of steam. Been a long week for both of us, and we decided not to push it.
We'll get the rest of the cork installed tomorrow, and I'll post more pics.
Chris
Minno 07-25-2011 07:59 PM
And the floor is finished! Per manufactors recommendations (and our son-in-law who used to install floors), we will seal it with 2 coats of water based poly this week. Most of it went down fairly easily - had to do some finnessing on the front due to the curves but overall not the hardest job we've done so far. We took Uwe's advice to lay the whole floor before we started building cabinets. It definitely about doubles the price of the floor, but we decided it would be the best way and worth the price. It took 8 boxes of 3 x 1 ft boards (7 per box). We did not do cork the last 4 ft as that is vinyled for the bathroom. There is a definite difference in the warmth of the cork floor as compared to the vinyl in the bath - the vinyl is much cooler on bare feet. There'll be rugs on the bath floor, though. We are very happy with the look!
Kay
Top 07-25-2011 08:01 PM
Beautiful! Cork floors are great. Nice work.
reinergirl 07-25-2011 08:44 PM
Love the variations in the floor. Would you share what brand/name you used? Its really beautiful!
