-   -   Need advise for sag check on 30 ft 1968 Airstream (https://www.airforums.com/forums/f36/need-advise-for-sag-check-on-30-ft-1968-airstream-49878.html)
LAWFISH 04-02-2009 11:57 AM
Her gang, I am looking at buying this 30 Ft Soverign Airstream. Its for sale locally and is a rear bath. I am told to be carefull of rear bath mods as they sag. What do I need to look for and what or how do I need to do to fix or stop potential sag if it is in fact not saged yet?
Does that make sense????
This trailer has been sitting in the same sport for over 20 years in a very very dry norhtern Nevada climate.
Thanks for any advise in advance of making an offer on this trailer that the owner wants $1800 for.
Dave
Inland RV Center, In 04-02-2009 02:02 PM
Dave
It's not a "sag" but rear end separation, where the frame is pulling away from the shell at the rear.
You can probably bet on a set of axles, since the trailer has not moved in 20 years.
CanoeStream 04-02-2009 02:04 PM
Squat down at the roadside & curbside front corners. Sight along the lower side skin and look back past the wheel wells. Is there any skin distortion aft of the wheelwells?
Squat down at the back bumper. Put a nimble person up on the bumper and have them bounce on the bumper slightly at first. Is there any movement between the bumper & shell?
These desert Airstreams do tend to be in better shape. Is there any apparent damage from the rear compartment door being missing? Nice to see that the side Corning windows are still there. Are the frames for the front & back windows hidden under the chipboard?
Nice looking year!
tphan 04-02-2009 02:04 PM
Short answer is go stand on the rear bumper and bounce a little- if you notice any deflection between the bumper compartment and the shell above it, you've got sag. Or get down there and look- a gap in that area will be reasonably obvious. Better yet, look through other threads here that deal with sag/separation, you'll learn everything you never wanted to know... But- it can all be fixed! Good luck and have fun!
