-   Steps (https://www.airforums.com/forums/f475/)
-   -   Can't figure this out (https://www.airforums.com/forums/f475/cant-figure-this-out-47990.html)
streamdreame 02-04-2009 10:48 PM
Hello fellow Airstreamers.
I don't know how this happened but the steps to my 73 Sovereign are stuck in a weird position and I can't get them to go back to normal. Does anybody have a solution?
I posted a pic at https://tinyurl.com/c8k5qt or https://www.airforums.com/photos/show...mageuser=16306
and I would be grateful if somebody let me know how to fix this.
Thanks!
Wally
DEITZ645 02-05-2009 05:37 AM
streamdreame,
The little lever to the right of your top step has to be pulled/pushed to release the the top step. Then you should be able to properly stowe your steps.
streamdreame 04-08-2009 07:10 PM
The lever wouldn't move one bit as it was stuck between the step and the bottom of the door. I removed the silver button on the lever with an hex key which gave me enough leeway to move the lever. Voila!
overlander63 04-08-2009 07:24 PM
Stoopid question...
Why didn't you just open the door?:rolleyes:
Mikethefixit 04-08-2009 08:43 PM
Wally
U should not feel alone. If I have not operated the steps for 2 weeks I forget how. Lub all joints helps some ,just don't get frustrated. U will get it.Fold it back up and start over,it will come to ya.
Roger
streamdreame 04-09-2009 12:37 PM
The door could open. I meant to say it was stuck between the step and the body of the trailer so the lever wouldn't move neither up nor down.
Lumatic 04-09-2009 02:32 PM
The stairs are aluminum the pivot points, tracks and attachment points are subject to wear causing the whole stair unit to become loose and sloppy and possible bind and get stuck.
