-   -   1986 isuzu trooper ll, fuel pump, ignition (https://www.airforums.com/forums/f463/1986-isuzu-trooper-ll-fuel-pump-ignition-46884.html)
taylortbutts 12-12-2008 07:41 AM
:blink: I took off my fuel pump, (mechanical), and now I can't seem to find where the return line from the fuel pump goes. Any ideas?
Had the starter bench tested and it checks okay. Primary to starter is good and hot, 12v. Exciter is good and hot 12v. when ignition is turned on, however is won't throw the starter. If I jump from battery to the small post, (exciter), then it starts right up. Any ideas?
TwinkytheKid 12-12-2008 09:00 AM
Welcome to the Airstream travel trailer and motor home forums.
Maybe you'd get a more knowledgeable response on the Isuzu forum.
