-   Belly Pans & Banana Wraps (https://www.airforums.com/forums/f476/)
-   -   Belly Band on 31' 1978 Exella (https://www.airforums.com/forums/f476/belly-band-on-31-1978-exella-4183.html)
Jim Miller 04-02-2003 08:38 PM
I am new to this forum. I am currently polishing (having polished) my Airstream that we have owned for 15 years. I am looking for someone withn the original dark blue and light blue stripe on aa 78' Exella. I need the width dimensions as they were remove befor I was able to get the dimensions, I have the rear panel but not the side stripe. Thanks for your help!
wb13798 04-03-2003 07:38 AM
i noticed that on ebay someone has the trim up for auction. search airstream. or call sonny at 205-665-2531 he is a airstream parts dealer and he might have it if not he could tell you which size you need.
lol
al
Jim Miller 04-03-2003 12:31 PM
Thank! I'lll give him a call.
startrekker2001 04-03-2003 01:33 PM
Belly Band.
I have a '78 31' Excella. See photos.
Try www.inlandrv.com. Then click on PARTS and then 'find' INSERT. That will get you to the 1/2 inch blue insert that goes around the vinylclad aluminum band. A 50' roll is $30. The 11/8 inch wide 50' roll for the bottom rub rail is $40. If you are talking about the 81/4 inch wide vinyl clad aluminum blue band, good luck. Those are not available as far as I know.
If the wide vinylclad is in bad shape, you can paint it with Rustoleum Royal Blue. It is a perfect match. I used a 4" smooth foam roller and it did a credible job. Others may disagree.
Vic
Jim Miller 04-03-2003 01:47 PM
Balley band
Vic,
Thanks for the response! I am talking about the wide band, but I have the 3M vinyl cutting equipment so I can reproduce the stripe if I can get the dimensions. The stripe I am looking for is the light blue one you removed from your trailer.
Your trailer looks awesome and has me excited to finish mine!
Is your trailer hard to keep that shine? How do you do it?
Thanks!
Craig 04-03-2003 05:43 PM
Jim,
Is this the stripe you are talking about? If so, I can measure mine this weekend and let you know then.
As you can see, mine is in bad shape and I plan to remove it like Vic did.
Craig
Jim Miller 04-03-2003 09:00 PM
Belly band
Craig,
Thats exactly it! This forum is a fantastic way to learn things about our A/S, thanks for the photo. I would appriciate it if you can mearure yours for me. If you would like I can see how much it would cost to send you a replacment stripe. I have a sign company I do a lot of buisness with, he may give me a good price.
Thanks again!
pap 04-04-2003 01:32 AM
Jim the wide blue stripe is nowhere near the belly of the Airstream.;)
Measuring the blue stripe would entail guessing how much of it is actually under the extrusion molds at the top and bottom of it. It is an aluminum overlay piece. or Do you want the measurements of the white accent stripe which is apparently a decal on top of the wide blue band? My 74 Excella thankfully does not have that 'bad boy' stripe applied.
Then there are the narrow blue vinyl inserts which are slotted into the extrusion mouldings.;)
ALANSD 04-04-2003 06:19 AM
depending on if you are wanting to keep to exact originality or not, if you search "tape striping" and tape stripe, etc on EBAY you can get rolls of really nice 3" wide tape to fit that area. I did mine in a different color than the original, that did match the other colors on my motorhome. Got 150 foot roll for 30 bucks. Looks really good, and was not too hard to accomplish.
Jim Miller 04-04-2003 07:15 AM
Tahkns Pap! I'll check that out
Jim Miller 04-06-2003 12:55 PM
Craig,
Have you had a chance to measure the stripe on your trailer yet. The one in the picture is exactly like mine.
Craig 04-06-2003 01:40 PM
I was just getting online to respond!
The stripe is almost exactly 1 1/4", with a 1/4" strip on top and bottom.
Hope this helps. Let me know how you make out. And yes, let me know how much to replace the stripe - I may be interested.
Craig
Jim Miller 04-06-2003 04:18 PM
Thanks Craig! I'll get back to you next week.
