-   -   2005 Suburban 2500 brake pads & service (https://www.airforums.com/forums/f463/2005-suburban-2500-brake-pads-and-service-41230.html)
boondockdad 04-14-2008 12:46 PM
not crazy about the stopping distances on my 'burb
anyone shell out $$$ for HP pads/rotors? like hawk, brembo...
I'm thinking it is what it is, same surface area, same sizes... how much change in stopping distance is a different material gonna make... thoughts?
also- while inspecting the rear brakes... i noticed the torx head caliper bolt is tight to the leaf spring assembly... i'd need a real low-profile ratchet... any tips?
boondockdad 04-14-2008 12:49 PM
this is all i found.. https://www.airforums.com/forums/f463...ads-13267.html
Bambi_Bandit 04-14-2008 01:17 PM
I switched to ART rotors and High Performance Friction pads:
Applied Rotor Technology
I found improvement in stops on the my heavy 3/4 ton Excursion diesel....
The rotors are cryogenically treated to withstand heat, and slotted to dissipate heat.
Came in handy when I forgot to plug in the trailer umbilical cord when I left a campsite. Looked down at the P3 brake controller and noticed no brakes as I was going downhill....
I have also noticed the stopping power better in emergency braking. Was cut off and hit the brakes hard. (no trailer at the time - truck alone). Much more confident stops than the OEM rotors and pads.
overlander63 04-14-2008 04:07 PM
You can get a Gearwrenchto fit the hex part of the torx socket, then you can use the Gearwrench to turn the torx socket.
boondockdad 04-14-2008 04:41 PM
yeah, a ratcheting wrench.. then use a male2male 1/2" drive connector... thanks.. a shorter torx would help.. but its a T55, which is pretty darn big, and all the ones i've seen are tall
i'm a little concerned... i've heard the older 3/4 ton subs, you had to drop the axle to pull the hubs... yikes
boondockdad 04-14-2008 06:23 PM
found it online... yes- passthrough system... that looks what i'm looking 4, thanks
XL PASS-THRU SYSTEM > Vortex™ Bit Sockets > Torx® > | GearWrench™
