-   -   Small metal plate on end of frame (https://www.airforums.com/forums/f36/small-metal-plate-on-end-of-frame-40840.html)
Lothlorian 03-30-2008 02:04 PM
I have two metal plates that go on the frame under the floor. One on each side. Look at the pictures and please tell me how to install these correctly. I want to put this in correctly. What order does this go? ( Frame, aluminum flashing, floor, C-channel ?). Please place these in order for me. I was under the trailer looking and I noticed that it will create a space between the floor and the frame. Is it suppose to do that?
SIU-Bound
Brian
Jim & Susan 03-30-2008 02:30 PM
Brian, those go inside the c-channel, inside the Airstream. Do you have these in both places (above the floor in the c-channel and below the floor)? I've got a couple of pic's in my Full Monte. Let me go look and I'll post a link.
Jim & Susan 03-30-2008 02:36 PM
Look at post 184 here: https://www.airforums.com/forums/213390-post184.html I actually added a couple back there to stiffen up that area.
Lothlorian 03-30-2008 02:39 PM
Jim:
I placed the floor in but it is not anchored in. It is a real tight fit. I don't know how I am going to put these in the c-channel and keep them from not moving. I will have to go out and look at this again.
Brian
Jim & Susan 03-30-2008 02:47 PM
I stated that badly, they go on top of the c-channel. Can you see them in the first picture in post 184 I mentioned above?
Lothlorian 03-30-2008 03:05 PM
Oh now I understand. Thanks. I only had two on mine how many did you put in?
Brian
Jim & Susan 03-30-2008 03:11 PM
Two extra, outbound of the main frame rails. Those two heavy metal "slugs" are there to hold the shell to the main frame rails using two large bolts. I replaced those bolts with stainless steel because the originals were so badly rusted (the slugs were also badly rusted, so I had a couple of extra made). If you need to, give me a call. Maybe I can explain it better.
Lothlorian 03-30-2008 03:25 PM
I will give you a call after dinner. I am the chef tonight so I am typing this as I am cooking a apple pie (Yuummm). I am really impressed with how clean your channel is. I never cleaned mine that well. I cleaned it but it does not look like new. What is the gel you have in the channel?
Brian
Jim & Susan 03-30-2008 03:32 PM
Apple pie? We'll be right over!:lol:
I cleaned the channel then painted it with a cheap can of automotive spray paint. I then sealed around all of the bolts with Sikaflex to keep water out of the bolt holes. I didn't want leaking water to drain down the holes into the new wood floor.
