-   Fresh Water Systems (https://www.airforums.com/forums/f443/)
-   -   City water inlet (https://www.airforums.com/forums/f443/city-water-inlet-39699.html)
Davis 02-13-2008 07:25 PM
City water inlet
Hi, I need to replace the city water inlet assembly on my 91 34ft excella. The one I have is chrome and is mounted to the roadside rear quarter panel. Would I have to get this from Airstream or can I get this from any rv dealer ?? I saw one in a catalog by shurflo but I am not sure if it is the exact same. Any advice will be appreciated. Davis
lewster 02-13-2008 07:35 PM
Dais,
They are available with or without a check valve installed and some can be had with an integral pressure regulator. You don't necessarily need the exact item....so long as it fits properly and does the job you require.:D
Davis 02-13-2008 07:41 PM
Thanks lewster, maybe I will try the shurflo unit cause I am sure it will be much cheaper than the OEM. Davis
