-   Fresh Water Systems (https://www.airforums.com/forums/f443/)
-   -   shurflo city water inlet (https://www.airforums.com/forums/f443/shurflo-city-water-inlet-35253.html)
urbanfood 08-18-2007 09:13 PM
will this shurflo city water inlet work for my flying cloud? it's got a built in pressure regulator, is that what i need? it also looks like it has a built in check valve. am i reading that right?
Water Mount Pressure Regulator (65 PSI)
GreatPumpkin 08-18-2007 11:12 PM
Looks good to go David. It's got a built in pressure regulator, AND the backflow prevention.
All Water Entries contain an internal backflow preventer to stop reverse flow through the unit when the potable water pump is used.
However, interesting note: further reading says
Use at least 1 ft of flexible high pressure tubing...must not be connected directly to plastic or rigid pipe.
clancy_boy 08-19-2007 06:45 AM
Looks Familure
That is what is on my 2003 CCD - Airstream is using it today.
urbanfood 08-19-2007 03:25 PM
great news. i'm going to order it today.
