-   Rock Guards, Segment & Window Protectors (https://www.airforums.com/forums/f469/)
-   -   Algae growing rock guard (https://www.airforums.com/forums/f469/algae-growing-rock-guard-34976.html)
Becky B. 08-09-2007 01:49 PM
This is what was inside of my rockguard when I opened it (figured it was an easy fix). I've cleaned up the window & recaulked, etc. Now I have to put the rock guards back on. They need new gaskets (where do I get them?). I would like to know how to prevent this green slime from growing again! It looks like it had an opening on the bottom for rain to drain out, but yuck!
Another question....The PO caulked the two rivets that I think are weep holes in the little gutters above the windows. Are they supposed to be caulked, or are they supposed to be open to drain water? I think it's the latter, but before I start digging the caulk out of the holes, I just want to double check. Thanks in advance!
Ganglin 08-09-2007 02:05 PM
If it's like ours the rivets are used to line up the window hook lip when you need to replace it in it's bracket at the top. They don't really do anything else. Ours are not caulked however.
Becky B. 08-09-2007 02:08 PM
Sorry about the picture....I guess I have to thin my file out or something. Won't let me upload.
Silvertwinkie 08-09-2007 02:11 PM
The weep holes I believe are for water to escape from the window.
Becky B. 08-10-2007 11:55 AM
I upgraded to a contributing member, so maybe I can upload this picture of my algae window now......
CanoeStream 08-10-2007 12:28 PM
Hi Becky -- I suspect the contact of the gasket promotes holding moisture up against the skin. Are you storing in shade so that wetness doesn't dry up very fast? This is factor #1 IMO.
Light is the other contributing factor and allows photosynthesis and algae growth. This is not like mildew where you have residues and maybe use bleach or a disinfectant -- soap and water only is what I'd use. I'd try sponge-soaping the gasket too and not think of replacing it.
Ganglin 08-10-2007 12:47 PM
Becky,
Gasket part number from Airstream is
Part # 685351.
HiHoAgRV 08-10-2007 12:49 PM
Oh that's horrible. Take them off and I come pick them up to rid you of those horrible guards that are gooing up your pretty Airstream:D
Becky B. 08-10-2007 08:51 PM
Part # 685351.
I thought these were an aftermarket item. The metal pieces that hold them in place are all rusty & falling out. I'll get in touch with Airstream & see if they have the same ones. They were like this when I purchased the coach, but it was parked in the sun with no trees around. I think water was trapped in there or something. Thanks for the advise & I think I'll keep them, HiHo!
Ganglin 08-11-2007 03:18 AM
Becky,
I sent one of the parts folks your photo and it only took them about 5 minutes to respond with the part number. If they have the gasket maybe they still have the brackets too. Have fun.
