-   -   Water filters in Classics (https://www.airforums.com/forums/f311/water-filters-in-classics-34716.html)
ralley 07-31-2007 02:24 PM
The Zeppelin (1991 350) has what appears to be a fitting for a water filter under the galley sink, but has no filter in it. It is metal, blue, round, fluted, and screws on and off. It is in the main water supply line to the sink faucet, not the heater for coffee-tea. (No photo before the weekend!)
Does anyone:
1. Have a similar fitting?:lol:
2. Know what filter is was made for (if any)?:blush:
3. Know a source for the filters?:flowers:
Lousy water in the campground last week!!:mad:
Best,
R
Lee Pace 07-31-2007 02:32 PM
We have one in our trailer. You can buy refills at camping World.
Gloria Pace
72 Sovereign
WBCCI 7287
Greenville, Tx
vswingfield 07-31-2007 03:01 PM
I replaced the one in my Excella with a GE from Home Depot. Not only is it better looking, replacements are easy.
Vaughan
lewster 07-31-2007 03:31 PM
I use a double filter on my CCD. The first being a particulate filter that is white and liike like spun fiberglass (it isn't though) and the main filter is solid block carbon (SBC).
If you're running just one filter, I would go with the SBC and add an in'line screen to the end of your hose fitting. It should work well, and you should notice a definite improvement in the taste and quality of your water.
I like my filtered water better than the bottled stuff you buy in the grocery, which uses a very similar process and is labeled 'spring water'.:huh:
ralley 08-05-2007 06:43 AM
Thanks, all. I can see I will need to make a trip or two to sculp out what's available--because it ain't '91 any more!;)
Best,
R
Chuckles 08-10-2007 12:03 PM
I have just removed the standard AS issue filter with General Ecology's Nature Pure.
Very neat - small, take up less space, comes complete with fittings and faucet.
It is much simpler to change and the water tastes good!
Chuck
