-   -   Trailer Frame seperation? (https://www.airforums.com/forums/f36/trailer-frame-seperation-33812.html)
Griswolds 07-01-2007 11:35 AM
Is this only common in rear bath floor plans?
Is this where the floor and frame fatigue from the body?
Does this happen to every model, and lengths?
Silvertwinkie 07-01-2007 11:37 AM
I think that it's more common on the rear bath units, but I think it can happen to any Airstream if someone were to do something like, say, put a spare tire or bikes on the bumper.
2airishuman 07-01-2007 05:25 PM
actually there is a whole LOT of old trailers...
with FRONT end separation....
often attributed to things like runniing gear balance or tv size...
neither of which are acceptable,
expect in extreme abuse cases...
also there are MANY newer units with front end separation...
door cracks, panel tears, window seal failure and so on...
this front end separtion issue in newer units hasn't been discussed much here...
yet
cheers
2air'
wahoonc 07-01-2007 07:16 PM
I will second 2'airs information on front separation. I had that on my 1975 trailer. In my case it was caused by leaks from around the front window that were allowed to continue and rotted out the wood and caused the bolt heads to rust off. We discovered it on the way back from a stay in mid Ohio when we noticed the shell was moving:blink: ran a cargo strap around it and drove gingerly the rest of the way home. Then tore into the front end, and the middle and the back:lol:
Aaron:cool:
dwightdi 07-01-2007 07:21 PM
Rear bath 31 footers are the worst, especially if they have gray tanks and the people traveled on rough roads with the tanks full. The frame either bends just back of the rear axle or the 4 inch frame fatique cracks at the same location. The hold down bolts between the shell and the frame (in the original configuration) are not strong enough to hold the frame up to the shell and you get separation. Two fixes were developed by the factory and many units had them installed. The first is installing bigger and more hold down bolts. This is called the elephant ear fix because they cut the shell from the outside to gain access and then install some ear pieces to cover the cutout. The second fix is the frame stiffeners which are bolted to the axle mounting plates. The real fix is when they went to the 5 inch high frame which is much stiffer and stronger. The shell no longer needed to hold up the weak frame.
