-   -   1990 land yacht electrical (https://www.airforums.com/forums/f37/1990-land-yacht-electrical-32598.html)
nana's ride 05-20-2007 02:22 PM
Hi, Have several questions, By mistake we plugged ac power cord into 220 instead of 110. Heard a few clicks then nothing. After plugging into 110 some things are not working. for instance light in micro works but not clock. Beside the engenius electrical box is there another breaker box. I have read other posts that talk about another box.
silverleeper 05-20-2007 02:49 PM
Ouch!!
Hi, If you have power to the micro and the clock is not working the circuit is fried. Did you try unpluging the micro for a minute or so and then plug it back in? Sometimes this will help.
azflycaster 05-20-2007 03:31 PM
If the unplug - plug does not work, check to see if the unit has any fuses that might have blown. If not, the unit is most likely toast. You may have fried your power converter as well. :sad:
