-   -   GE patio light H12 sealed beam (https://www.airforums.com/forums/f37/ge-patio-light-h12-sealed-beam-30782.html)
philippes 03-12-2007 11:00 PM
I have a Classic 36' 1994 Motorhome.
Do you know what is the right light used after the main door, at the compartment level. It is a GE H12, rectangular, Sealed beam with two pins in the back and unfortunately no reference. I have asked to many accessories dealer and they cannot find the right model. Where can I find it?
Thank you in advance for your help.
Philip
SilverToy 03-13-2007 01:58 AM
phiip -
I think that you can easily use the LED technology to power ALL the key points where other lighting was used, to were you went for interiour wattage. LED can do what it is cheaper/ and cooler/ and more efficiaently it was SO MUCH lower that any other contendor..... bar non. Compare watts/ amp-hrs and there is NO comparaison. LED ALL THE WAY!
Send specifics about the situatuon and "photos" whereEVER possible. Photos help when pages and pages of description doesn't do (DK) - all??????
Philip
lewster 03-13-2007 07:11 AM
I agaree with ST about going LED, but IIRC, you can find these at NAPA. The big Prevost busses use that same light in the entry doors to illuminate the area just outside.:D
philippes 03-17-2007 09:20 PM
I have found the genuine replacement part. Thanks fro help.
Philip
