-   Fresh Water Systems (https://www.airforums.com/forums/f443/)
-   -   Fresh Water Tank Fitting Sizes (https://www.airforums.com/forums/f443/fresh-water-tank-fitting-sizes-30550.html)
tgregory13 03-02-2007 11:58 AM
I need some help here... adding a fresh water tank to the 63 overlander, I know where i want my vent, fill, and pump connections on the tank i just dont know what size i should use for each. is there a standard for this??
markdoane 03-02-2007 01:54 PM
I used 1.5" for the vent and fill connections, and 1/2" for the pump and drain connections.
tgregory13 03-02-2007 02:17 PM
mark... did you cut those in yourself or did you order the tank with them pre-installed.... I dont know why but i have wore myself out with the placement and size of these fittings... i think i'm to the point were i'm just going to order it with no fittings installed that way if i need to make a change i can without haveing to plug one of the "factory" installed fittings...
markdoane 03-02-2007 03:15 PM
Todd,
I ordered my tank with the fittings installed. I placed the two vent openings in the upper inboard corners.
