-   Wheels, Hubs & Bearings (https://www.airforums.com/forums/f465/)
-   -   Dyna Beads wheel balance (https://www.airforums.com/forums/f465/dyna-beads-wheel-balance-28001.html)
LI Pets 11-19-2006 06:54 PM
Anyone use these to balance the wheels? I assume they should balance the running gear as well.
The site says high-density ceramic bead that, when easily installed, continuously balances your tires as you drive. The amount of material will distribute itself in weight and position dependent on the balance requirements of the individual tire.
The result is a smooth, vibration-free ride, derived from our balancing media that is always repositioning itself as the tire wears. If you own a pickup truck, RV and want to get rid of those wheel vibration and tire cupping problems, then you need to move up to Dyna Beads!
looks like 3 oz per tire cost about $15, you install them thru the air valve, and intstall a special insert.
You need not take the tire off the wheel.
S C Streamer 11-19-2006 07:58 PM
Never seen them till now,here is the same theory in a different approach. https://centramatic.com
LI Pets 11-19-2006 09:05 PM
a different approach, with a different $$$ by several hundred bucks.
doorgunner 11-19-2006 10:48 PM
Nothing new
these things have been around for quite a while. The offroad 4 wheeler guys use them on their mudder tires. Tech Supply in Kansas City has another brand. Or do a google search and read away.
