-   -   Engine Air Conditioner (https://www.airforums.com/forums/f311/engine-air-conditioner-27077.html)
Howard Lefkowitz 10-19-2006 06:22 AM
I need the R12 freon capacity for the 1990 through 1995 454 Classic Motor Home. Thanks.
overlander63 10-19-2006 10:58 AM
Starting in 1994, R134A was the legally mandated refrigerant. If you want to convert, when you find the specification for the R12, and if you can't find the R134A weight capacity, R134A is 80% of the weight of R12.
swebster 10-19-2006 11:49 AM
Terry,
You really do know too much about this stuff ;)
Nye Thatcher 10-19-2006 08:03 PM
I think at that time they were still using the G.M. receiver/dryer with the sight glass. If so, clean it off and charge until the bubbles stop. At this point add five more ounces. You may need a mirror to watch the flow under the sight glass.The pressure reading on your low side will be around 40 p.s.i. Good Luck.
Howard Lefkowitz 10-21-2006 09:12 AM
I want to convert to Redtek but the original R12 charge is not marked anywhere. I don't know why Chevrolet or Airstream did not provide the tune-up, freon, fluid levels etc. for these Motor Homes. The specs are different for each year and model and it would be nice to know what is needed for repairs. The Chevrolet Motor Home books provide some of the info but not all.
noiva 10-21-2006 03:06 PM
Sounds all too familiar. My Blimp has a Ford engine, and it's manual gives virtually no useful information. I have had very good success going to NAPA or Pep Boys and asking for engine things for a 1987 (last year of carbs on vans) E-350 Van with the 460 engine. So far every part or capacity has be correct. I even bought an after-market book for that year van, and it's full of useful info. May be an option for a Chevy also?:huh:
Best,
Howard Lefkowitz 10-23-2006 12:29 PM
And the answer is -------------
The consensus is between 30 and 35 oz of R-12 for the 1990 345 Models.
