-   -   man this is a big job! (https://www.airforums.com/forums/f36/man-this-is-a-big-job-26626.html)
rama777 09-29-2006 08:08 PM
I didn't realize what I was in for when I baught my 74 31' airstream. Wow. Luckily I am in love with it and I have two months to dedicate to finishing the job. I am to the point now where everything has been removed from the interior and I am ready to take the floors out. I know I need to remove the belly pan. I don't know how just yet but thank god for this site because I have the sources to figure it out! I am taking the flooring out basicaly because I want to inspect the frame. I have a pretty bad feeling about what it may look like. Taking the shell off the frame sounds like a nightmare and I don't think I can do it. So my question is, what can I do to fix up the frame before I put the floors back in? I was thinking I would just power sand all of the rust off the whatever frame I can access and then....I don't know. What should I do to protect it from more rust? Also, do I have to jack up the thing to remove the belly pan? I am very skinny so I have room to work with down there as long as the belly pan can be removed without jacks. Lt me know what you think. Thanks a million!
LI Pets 09-29-2006 08:19 PM
You may wish to save some work and leave the floors and drop the pans.
Wire brush and coat with POR-15, remove all insulation.
What Im doing is putting foil insulation on top of the floor.
to block it up see pic
CaddyGrn 09-29-2006 10:04 PM
What to do...
This forum has great ideas, help, and whatever you need! I am impressed you are tackling such a big job in 2 months! Good luck! We have a tiny trailer compared to you.... but my hubby has a good thread with lots of pictures. Many items might be the same for you, so you might want to review it. It is long....get a cup of coffee and go to it! :p
I would recommend looking under the belly pan before you remove the flooring. If the flooring is solid... you might get away without taking the shell off...depends on what you want to do.
Anyway, good luck on your project and here is the thread I mentioned:
https://www.airforums.com/forum...mbi-17925.html
Mrs. NorCal Bambi (traveling in S Tardis)
