-   -   Need frame diagram for 19' Bambi remodel (https://www.airforums.com/forums/f36/need-frame-diagram-for-19-bambi-remodel-26332.html)
cmugler 09-18-2006 11:03 PM
I just bought a 2005 19' Bambi and will be doing changes to interior including removing dry bath unit, replacing with a smaller wet bath and installing a larger bed across the rear. I need access to the details of the framing so as to make it easier to reinstall plumbing etc. Any help would be appreciated Charles
mswartz 09-24-2006 04:42 PM
I've attached three .PDF files for the 19ft Bambi. They apply to my 2001 19ft Bambi, but I cannot say if they are applicable to your 2005 19ft Bambi.
915474, rev G (6/01), Chassis weldments.
915531, rev N (1/06), Chassis prep.
964465, rev H (3/06), Floor cut out.
Contact Jim Parrett at Airstream Customer Service if you want further information or drawings.
I modified my Bambi bed pedestal, freshwater and 120VAC wiring, and found that the drawings were helpful. I ended up transferring the drawings and actual measurements on my Bambi into autocad for planning the job prior to the modifications.
