-   -   towing capacities (https://www.airforums.com/forums/f464/towing-capacities-25335.html)
coldandhardy 08-16-2006 02:14 PM
towing capacities
Hi,
I am new to this forum and I am looking to purchase a new or used airstream trailer. I have a 2004 VW Touareg SUV, V10 TDI (diesel) with 500+ ft. lb. of torque and 300 + h.p. It is a 6 speed automatic 4WD . It has 18" tires that are quite wide. It's hitch capacity is listed as 616 lb. and tow capacity is listed as 7700 lb.
When I look through the specifications page on Airstream's web page I qualify for several larger trailers (up to 7700 lb.) but the unadjusted hitch weights on all but the smaller models are dissappointing high. There is a mention on the hitch weight line that seems to suggest that weights or presumably loading of the trailer adjusts the hitch weight. I think I know what this means but can anyone fill me in?
I already figured out that personal belonings will increase the weight of the trailer so my target starting weight should also be less than the max. of 7700 lb.
Chuck 08-16-2006 03:11 PM
Welcome to the Forum!
can't help you too much with specifics...this is a unique tow vehicle, and has generated some controversy in the past, but I'm pretty sure there are a couple of Toureg owners here who might be able to help.
Some of the numbers with this vehicle just don't add up. There's nothing "out of line" about the Airstream fleet's hitch weights; Any trailer, of any type, should carry 12-15% of its gross weight on the hitch; otherwise, the combination would be dangerously unstable. So for VW to claim a 7700lb max towing capacity, with the limit of 616lbs on the hitch just doesn't jibe. You can't have 7700lb tow capacity without a minimum of 900lbs on the hitch. some might say "10%"...still, that would require 770...
My understanding is that this vehicle has a special hitch, and a self leveling suspension that precludes the use of any weight distributing equipment, also...so that's of no help.
Unless I'm missing something, (which is entirely possible), it seems that with a 600lb hard-limit on the hitch, you're really limited to a trailer that weighs no more than 5000lbs, gvw. that's the trailer, all its options, and all your stuff on board.
yes, the hitch weight will vary some based on how the trailer is loaded, (too much or too little fore or aft) but you don't want it outside that 10 or 12-15% range.
