-   -   hot water heater flare up!!! (https://www.airforums.com/forums/f445/hot-water-heater-flare-up-23301.html)
glacierrunne 06-04-2006 09:41 PM
Got most of my plumbing leaks fixed so decided to light the hot water heater.It's a 6 gallon Atwood. The pilot light was easy but when I turn the knob to ON ,it FLARED up by the slide air shutter. I was able to turn it back to pilot right away---- soooo no harm but I've got all the manuals out and want to know if there is any help out there on this one. I've got a 1980 Caravelle. Thanks, Don
peegreen 06-04-2006 09:52 PM
Try taking off the burner tube and cleaning it out. A favorite place for spider webs and nests causing gas blockage and flare ups as you observed.
lewster 06-04-2006 09:54 PM
Sounds like the LP delivery system needs a thorough cleaning. Take everything apart, clean the burner and orifice, all tubing, etc. It should take care of the problem unless you have a propane leak somewhere else. Also, be sure that the air mixing opening is properly adjusted.
john hd 06-04-2006 10:01 PM
yup
sounds like bugs in the pipe.
john
glacierrunne 06-04-2006 11:08 PM
Thanks guys! That makes sense, since the trailer has not been used for several years. I have two more plumbing leaks( hate those gray fittings used in the 80's) to fix then will clean burning tube. I'll let you know what I find! Thanks again, Don
glacierrunne 06-05-2006 10:50 PM
Big Time Spider web, cleaned it out and everything works just Fine! Thanks again for the Tip. Don
