-   Refrigerators (https://www.airforums.com/forums/f425/)
-   -   How do you get the fridge out??? (https://www.airforums.com/forums/f425/how-do-you-get-the-fridge-out-23053.html)
mickfly 05-26-2006 12:01 AM
I have a 65 Tradewind. I can't figure out how to get the fridge removed. Is is bolted on the bottom? and the sides or what? It's hard to see the bottom because of the shell underneath the trailer. . .
GreatPumpkin 05-26-2006 12:18 AM
Pictures would help.
Mine is screwed through the bottom "runners" to the floor, and through the side from the adjoining cabinet. You will have to remove the wood panel on the end to access the bottom screws.
InsideOut 05-26-2006 12:22 AM
It's a bugger!
We had to remove ours out of our '64 GT a couple of seasons ago. I'm sure each model varies a bit based on size, location & interior configuration. But we had four bolts through the floor that could only be accessed through the vent in the belly pan under the trailer. It would have been better if our arms had extra joints to bend the way they needed to! ;) These bolts attached the bottom support runner of the fridge securely to the floor. There wasn't anything else as I recall, but we struggled with just those four #@!*&% bolts for the better part of a day...definately a two person job. One to hold the bolt on top the other to loosen it from below.
I know I've heard and read of some that you have to disassemble a credenza or part of the kitchen cabinets to get to some bolts as well.
Hopefully someone with the same trailer can help out with more specifics...in the meantime, take a look below to see it this helps.
Shari :flowers:
balrgn 05-26-2006 05:06 AM
If it is anything like the mid 70's there is a plate on the floor and wall that screws to both. :cool:
This pic kinda gives you the idea.
mickfly 06-14-2006 11:56 PM
I got the fridge out!!!
"I finally got the thing out. There were four bolts on the bottom but it was screwed in from the closet. The screws were covered nicely with wood dowels countersunk into the wood. Hard to find!!! Good craftsmanship."
