Interstate X Smart Shunt
Hi
One thing that crept into the X without a lot of publicity is a Victron Smart Shunt. If you look at the AS manual for the X, it's in there. If you dig into the CS bench and look just aft of the inverter, it's sitting there. The odd thing (at least on my X) is that it does not show up on the Victron App. On the shunt, there is a green terminal block on the side. According to Victron, you need to run +12 to that terminal block to power the device via a fused wire. Oddly enough that wire is not connected. It's bundled up about 6" away by a Blue Sea gizmo .... Getting to the terminal block probably involves pulling the bench .... Fun !!! Bob |
Red wire with fuse holder?
Pics attached. Are you referring to the red wire with fuse holder?
Yup that's the one. On mine it was still nicely tied up at the source end. This was the first production X that went through my dealer. I don't think they knew the Smart Shunt was supposed to be there. Bob |
Hi
Since the wire is a push in connection to the Smart Shunt, getting it hooked up was a lot easier than I had though it might be. Once powered up, you go through the usual connect process to the Victron App and do the two sets of firmware updates. After that, you can program thing up to match the battery. Now all we need to do is wait on the blower motor for the front heater .... It died during pre-flight at the dealer. They let me know before I came over and I made the call to still pick up the van. Bob |
24X Blower Motor Failure
That failed on ours, too, and someone noted on the 24X Facebook group it had failed on theirs as well.
I ordered spares from an electronics supplier, as it's a four and a half hour drive to the dealer to replace a sixteen dollar part. Mechatronics F1238X12B1 |
Hi
Wonder who has them in stock..... Bob |
Master Electronics has them in the US. Minimum order quantity is two.
Hi
Ok, they have 2 less in stock now :) Full part number seems to be F1238X12B1-FSR. There is also a -FHR running around. It has a different impeller. Not sure how much of a difference that makes. Bob |
How much effort is involved in getting to/replacing the blower? Mine failed this weekend.
The replacement is straightforward if you are handy and have the right parts/tools. Proceed at your own risk.
Make sure the heater is powered off. The replacement fans I received didn't come with the Molex connector attached. I reused the existing connector by splicing it on with the same Ancor waterproof connectors I use on our boats. This takes a special installation tool I already owned. If I didn't already own the tool I'd have spent more time sourcing a match for the original connector. If doing a splice make sure to match up the color of the leads. Removing the drawer below the pantry provides access. The fan is mounted to the rear of the heat exchanger and is held on by four Phillips fasteners. It takes a stubby screwdriver to remove them. The Molex connector unsnaps. Removing the fasteners is easy. So is dropping them and having to fish around with a hand and/or magnet. Don't be surprised to find other fasteners and tools left behind during factory assembly. It's best not to drop the fasteners. There's a chromed safety shield attached to the fan that comes off with it and goes back on the way it came off. Make note of the orientation of the fan during removal. I believe it goes with the label side toward the heat exchanger. I forgot to do this and had to rig up a bench power supply to test. Taking a photo would have been the smart thing to do. Take a photo. Replacing the screws requires a mirror or more patience than I have. I'd bought a suction mounted rearview mirror for the van and this worked a treat once I managed to pry it off the windshield and stick it to the wall behind the heat exchanger. Snap the Molex connectors together. Test. Remember to remove the mirror before putting the drawer back in. Else curse, remove drawer, remove mirror, reinstall drawer. Letting the dealer do all that is the best option if available. |
Hi
I'm beginning to wonder just how many fans one should have in stock. They seem to be dropping like flies .... I would *guess* ( but don't know ) that there are a lot of other fans from other outfits that would do the job. It appears to be a very standard size and configuration / power level. They are cheap enough, but replacing them sounds like a PIA. It also sounds like sourcing the magic Molex connectors might be a good idea. That would mean diving into work out the part number on whatever one they used. There are a billion or so different versions ..... Pre-stage the spares inventory with connectors on them. Bob |
I called Elwell/ Timberline about the fan. The service technician was very helpful. He had me test the voltage(12.94) coming to the fan. They are sending a replacement unit. They are aware of some fans failing but not sure why they are failing.
Elwell customer service was way better than Airstream/Jackson Center. Jerry |
I very much get the impression that parts shortages have worn out a lot of the CS folks. Things go into limbo land and never come back out. The "what about the cellular prewire?" question also seems to be in the same AS limbo land as the fans. When the replacement gets in, take a look at the part number on the fan. Let us know if (maybe) they have more than one PN they are using. That would not be a big surprise .... For super bonus points, a picture of the Molex connector / which wire goes where would be really cool. Thanks Bob |
Search on Amazon for:
2-Pin Molex 2.13mm (.084") Connector Kit, 14-20 AWG Arcade Pinball (3-Set) I tried the 0.093 and the 0.062 pins and they are too big and too small respectively. These 0.084 seem to be the same size pin and connectors as used for the fan. |
Previous posts have suggested that the fan is a three wire affair with a tachometer lead. That would suggest a three pin connector .... Confused !!! Bob |
The white (speed control) lead is unconnected. On the factory fan it was simply cut off and the bare end left uninsulated.
I shrink wrapped the end on the replacement fan but otherwise left the lead intact. The fan installation calls for only power and ground. The connector XMan refers to is the correct connector. |
Hmmm ..... that's silly. Why design in a tach fan when you aren't going to use the tach feature? Way better (and more reliable) to just design in a basic two wire fan. I wonder if they *did* design in a two wire fan and it went on shortage? Off they went to grab anything they could find to fill the gap in inventory. This beast came in and now they have failures .... hmmmm .... Bob |
