-   -   EZ lube axles (https://www.airforums.com/forums/f437/ez-lube-axles-229886.html)
geraldsmith 11-30-2021 08:56 PM
EZ lube axles
If you have Dexter EZ lube axles on your Airstream--Beware--
Do not use a grease gun to repack the bearing. It is too easy
to pump too much grease, blowing past the seal and fouling the
brake assy.
Instead of the grease gun, spend the extra money to have the bearings
repacked the conventional way.
