-   Rock Guards, Segment & Window Protectors (https://www.airforums.com/forums/f469/)
-   -   Enkay Rock Tamers: Trim Length (https://www.airforums.com/forums/f469/enkay-rock-tamers-trim-length-22894.html)
Tin Diesel 05-20-2006 08:54 AM
Based on rave reviews in this forum, we just purchased the Enkay Rock Tamers for our F-250 and 30' classic and I will be installing this weekend.
Question to those who have the Enkays: how high above the ground did you trim them? Put differently, what ground clearance did you allow?
Thanks.
Alumaholic 05-20-2006 09:16 AM
Just Follow the Instructions and You'll do Fine
Greetings KJ,
You are going to love your Enkay Rock Tamers. The installation takes about 45 minutes if you follow their instructions.
Just remember, before you measure the required length of the flaps, you must hitch up your Airstream just as you would when you are going to tow it. Enkay recommends 3" to 4" inches off the ground, when you are hitched!
Use a good, steel straight edge like a carpenter's square, a utility knife with a new blade, and a piece of plywood as your cutting board.
BradS 05-20-2006 12:47 PM
You will enjoy the Rock Tamers they are great. I trimmed mine off at 3" above the ground. I want all the help I can get keeping rocks from hitting my trailer. I used a saber saw with a metal cutting blade to trim mine off
pmclemore 05-20-2006 02:28 PM
Be sure and note that the hollow metal tube is not a punch, but is instead intended to be used as a drill bit for bolt holes.
If you use it like a punch, as I did (having failed to read the directions), you will end up with having to find something else to make the holes with.
Pat
Alumaholic 05-20-2006 02:37 PM
Pat is correct. If used as a drill bit, the hollow metal tool works amazingly well... unless you allow it to fill itself up with plugs. Then, you have to spend about 30 minutes digging the plugs out so you can finish the last three holes. Don't ask me how I know this.
flyfisher 05-20-2006 03:20 PM
Howdy, twin! I also have Enkay's on my F250, towing a 30' Classic. (4x4 truck)
When you trim them, as others have suggested, remember that you'll also be able to affect the length by tilting them forward or backward after they are cut off and installed. And, you can always cut off too little, and go back later to cut off more if needed, but if you cut off too much the first time...I'm sure nobody ever did that!
I have large mudflaps behind every tire on my truck in addition to the Enkays, and I still have a bit of gravel dings on the front of my trailer. I'd hate to think what it'd look like without them.
Tin Diesel 05-20-2006 03:45 PM
Job done
Thanks everybody.
I cut them at 3.5". If needed, they can be lowered a bit by adjusting the arms.
Just for the record, per the directions, I used a new blade in a box-cutter knife and cut the flaps along a steel edge (T-square) on a board. Worked just fine... took about five passes to get through.
Also per the instructions, I used the steel tube as a hole punch. It was quite sharp at the cutting end, and did a great job. Since it was hollow, I just pushed the plugs out from the other end with a skinny screwdriver.
Everything seems to be shipshape. We'll be travelling Houston-Steamboat Springs soon, so we're ramping up to prep the coach.
Thanks again.:)
