Ceiling LED bulb replacement 2016 Flying Cloud
One of the LED bulbs in the 4 dimmable ceiling spot (pot?) lights is out in the bedroom ceiling of our 2016 Flying Cloud 25 FB Twin. It's the nearly flush 3"+ diameter chrome-ish fixture with a frosted lens about 1.5" diameter in the centre. I need to know:
1. how to get the fixture down/open, 2. what bulb replaces the failed LED, 3. where to get the bulb (I'm on Vancouver Island in Canada). If I grab the circumference of the whole fixture and gently pull down, the fixture comes away from the ceiling about ¾" and comes to a stop. As I pull it feels like it's being resisted by something springlike . I hesitate to pull harder to see if it's a spring/clip type latch without asking whether someone has done it before. My handy-dandy Parts Manual (page II-33) gives this description for the LED (I think): "Part 512718 Spotlight, Recessed, LED" But there's no diagram, so not very helpful. Anyone done this before? Gary |
I also found this link to a USA replacement
https://highskyrvparts.com/new-airst...ght-led-512463 Do I have to replace the whole fixture for $48 USD?! Gary |
As far as I know, yes you do. Crazy design I know. The bulb is retained by two spring clips inside the skin of the trailer.
https://www.airforums.com/forums/f44...ns-146801.html Gary |
If you are not wedded to the exact pattern of the Airstream version, there are a number of 12v recessed lights that might be a good substitute. Some examples are listed below (note that the prices are for more than one light).
Tim https://www.amazon.com/acegoo-Recess...012KCNN5O?th=1 https://www.amazon.com/Ceiling-Reces...07544JW2F?th=1 https://acegoo.myshopify.com/product...-3-5-5w-4-pack |
OTOH, If you can do very fine soldering and scrounge for parts, you can replace just the LED part... but frankly the effort may fail or take hours to do, so buying a whole fixture makes sense in a time vs. money world. |
If you go the "solder in a new LED" route, you will need to identify the exact part they used originally. If you put something else in there, the light is likely to look odd compared to the other fixtures .... Bob |
We've bought many LED lights & fixtures for the AS,house and vehicles here.
I've found buying quality pays off in the long run.👍 Bob 🇺🇸 |
