-   Refrigerators (https://www.airforums.com/forums/f425/)
-   -   2021 Norcold Elec-Only Fridge: Door Opening in Travel! (https://www.airforums.com/forums/f425/2021-norcold-elec-only-fridge-door-opening-in-travel-225947.html)
CMHM 08-02-2021 07:29 PM
I am in a new 2021 Globetrotter and recently found fridge items on my floor after driving. Initially I thought I must have had my head in the clouds, but now realized the fridge door opens during travel. The little pin (crazy how small it is!) doesnt latch fully because the door now sits ¼ in too low and the pin doesnt fully extend.
I haven't found much on this forum, but it seems like this is ongoing issue in many other forums (see here).
To me it doesnt look like ordinary washers will do, so I am wondering if anyone had this issue yet and can advise how they fixed it?
(I know this is a warranty issue, but my Airstream spent 5 weeks at JC already and I just want to get this done myself).
CMHM 08-03-2021 09:04 PM
Anyone?
AirstreamInc 08-04-2021 07:34 AM
Hi CMHM,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
CMHM 11-15-2021 05:57 PM
SOLVED:
Airstream kindly sent me a new fridge door. I removed the central hinge (the one holding the bottom of the freezer door and the top of the fridge door) from the fridge to remove the doors and realized the issue is that the main fridge door was simply sitting too low. The height of the fridge door is adjusted with little plastic washers/spacers, and considering how flimsy they were on mine, some of them must have broken under the pressure of the fridge door resting on them. As a result the locking pin would no longer extend into the door handle and the fridge door swung open during travel multiple times.
I have attached two images showing how I solved the situation with a much more sturdy nylon spacer. I would highly recommend this quick fix for all owners of the electric-only Norcold fridge, you don't want to find the inside of your fridge spread out over the floor.
Ask me how I know... :lol:
dog_and_cat 01-19-2022 08:01 AM
Same issue, same trailer
Hi CMHM - same exact issue here and I now have a nice dent in the fridge door from it hitting the closet door handle (not to mention the mess on the floor).
Before seeing your post, I called the NorCal support line and they said that I had to pull the fridge/freezer unit 4” out from its enclosure to remove the fridge door. Seemed like BS based on the look of the door hinges.
I’d like this to be a quick fix as we’re currently traveling and don’t want the doors open/off for very long. Can you just confirm the model number of your fridge for me? I just want to be sure that we’re dealing with the same door/hinge arrangement. Mine is the N8DCSSR.
CMHM 01-19-2022 10:11 AM
Yes it’s the same exact model. Two weeks ago this very fridge stopped working for me. I had a repair guy come out and we pulled it out of its enclosure and realized they installed a refurbished (not new) model that was covered in duck tape - prob because of an earlier cooling liquid leak.
I had it replaced with a Dometic model and now I’m waiting to hear from Airstream about the warranty work. Infuriating.
dog_and_cat 01-19-2022 04:37 PM
I got the door off, raised, and back on this afternoon in <5 min. Nice secure closure now.
I’ve had so many of these kinds of issues that come from Airstream’s poor workmanship. It’s really disappointing.
Thanks for your help on this.
Chris
Sumbike 01-19-2022 05:22 PM
Had the same issue, but the door didn't open while traveling, came off in my hand when opening it after travel. Found the small screw on the floor. Reinstalled the screw and the door sat too low and no longer latched with the upper latch. The dealer did fix it and it seems okay now.
How about the plastic drip panel below the evaporator at the top of the fridge, does it fall out of the grooves on the insides of the fridge every trip? The dealer had no solution other than offering that it is wider at the front than the back so must be installed in the right direction. It still falls out of the grooves.
dog_and_cat 01-20-2022 03:42 PM
That’s one issue that I haven’t had.
