-   General Motorhome Topics (https://www.airforums.com/forums/f160/)
-   -   Fuse box (https://www.airforums.com/forums/f160/fuse-box-221683.html)
Kitester 04-16-2021 05:30 AM
Fuse box
Hi to all!
I have just restarted my 300 project and have a few questions. The most important one at this time is about the original fuse box. I looked for a diagram but the best I can find is the hand drawn black and white pic in the operators manuel. No color codes are shown and the best graphic is a general line drawing of what is connected to what. So part of the question is "Where can I find a real wiring diagram with color codes and individual devices, i.e. red wire to roof fan?" And the second part of the question is "what did the 300 need 50amp fuses in the 12 volt fuse box for?" I guess a third question might be "What are people replacing it with or where can I find that part?" Thanks
in advance.
Magnet18 04-17-2021 08:45 AM
For a diagram, if you're lucky a service manual still exists for the 300, if not what you have is what you got
The 50a fuses, I can't guarantee, but probably for the battery charger
OTRA15 04-17-2021 09:43 AM
FYI there is a Classic Motorhomes sub-forum which includes your 310, with many threads loaded with details:
https://www.airforums.com/forums/f311/
In June 2020 you posted in the Sticky Topic in the forum above:
https://www.airforums.com/forums/f31...ml#post2371809
Re: 310 see also:
https://www.airforums.com/forums/f31...-a-178802.html
https://www.airforums.com/forums/f31...et-178642.html
Good luck.
Kitester 04-18-2021 04:38 AM
Thank you guys. I did get some good information from your replies. I especially liked the info and pics of the gear vender installation. It is unfortunate however that the wire diagram in the manual is so lacking. If I was working on almost any other vehicle the diagram would list the components as well as show the wire size and color. Is there a service manual that can be bought like a shop manual? Where would it be available?
