-   All Argosy Trailers (https://www.airforums.com/forums/f227/)
-   -   72 redo (https://www.airforums.com/forums/f227/72-redo-221419.html)
1972 04-10-2021 05:57 AM
72 redo
Iím doing a complete over hall just started the frame and under belly 👍
Biggmixx 04-10-2021 09:50 AM
Welcome to your new adventure. Post lots of pictures.
Dave
Bubba L 04-10-2021 09:53 AM
Welcome and please post some pictures. I donít know much about an Argosy, but would love to follow along to learn. Good luck
Eric 26 Argo 04-10-2021 11:06 AM
Cool glad to hear. I think you will find uploading photos will be the hardest part.
Peter417 04-10-2021 02:26 PM
A 72 what?
1972 04-13-2021 11:42 AM
72-argosy 24í and trying to post a photo
1972 04-13-2021 11:49 AM
Started with the under belly
The frame and wood look grate I custom made my replacement part
aaryno 04-13-2021 12:00 PM
I see the OP uploaded a photo. The rest of the reno is easy.
aaryno 04-13-2021 12:01 PM
Congrats! And Welcome!
Biggmixx 04-14-2021 08:47 PM
I like your fabricated crossmember. With a welder you can make anything. Most of my crossmembers were so rusted I couldn't use them for patterns. You doing shell on or off...it looks like you've got your belly off and working from the bottom.
Dave
1972 04-15-2021 04:38 AM
Frame on
Starting with the bottom cleaning and painting the frame insulation then removing the interior skins to remove mouse crap , the camper is useable condition we camped 3 times . Iím not putting the tanks underneath trying to make a 4 season camper planing on camping in Michigan over Christmas weak to test it out 😃
Eric 26 Argo 04-22-2021 12:29 PM
Camping in Michigan over Christmas????? You know the point of the wheels is so you can take them with you Florida during the winter.:lol:
Disable 05-01-2021 08:38 AM
This might be a silly question but what tool did you use to cut out the rear member? Also were you planning on replacing any of the rotted 2x4s?
1972 05-02-2021 03:51 AM
I used a grinder and thin wheel or cut off wheel , the 2x4 s are bad only about 3Ē I will install a new one right beside the existing one , and add weld a new bracket to the new ibem or cross member and attach the outher end to the frame cross member about 5 feet long I will not have to replace the plywood or frame off just the vary back 6 inches of plywood I will try to post more next week
1972 05-02-2021 04:57 PM
72 redo
Trying to post a photo of frame rail that I replaced and then showing wire brushed the painted rust proofer on the frame itís going nicely
