-   -   City Water filling Fresh Water Tank and Overflowing (https://www.airforums.com/forums/f163/city-water-filling-fresh-water-tank-and-overflowing-219741.html)
robertwarren 02-24-2021 11:19 AM
When I hook up my 2018 27 FC-FB to City Water the Fresh Water tank fills to 100% and spews water through the overflow vent. Is there a bypass or check valve I am overlooking? Please advise
azflycaster 02-24-2021 11:26 AM
Common problem. Check valve in the water pump is not sealing. Could just be some matter in the line. Running the pump will clear this up in most cases. Worse case will be to replace the pump.
OTRA15 02-24-2021 12:51 PM
Ditto.
These search results will lead to earlier posts/threads with further helpful information IMO:
https://www.google.com/search?q=pump...=airforums.com
great2beadaw 02-26-2021 06:39 PM
For what it's worth, we had the same issue. We decided to have a check valve installed. The water pump is extremely noisy now and we wish we had just replaced the fresh water pump from the start.
AKNate 02-26-2021 08:41 PM
We just had that problem on ours a few days ago, although it was more a drip than a spew. Turning off the city water and running the pump for a few minutes fixed it.
robertwarren 02-27-2021 08:02 AM
Fresh Water Pump Replacement
Thank you all for your help. I have decided to replace the fresh water tank pump. I have been told that their is a variable speed pump upgrade out there. I would appreciate any replacement pump information. Again...THANK YOU
(2018 Airstream Flying Cloud 27 FB)
AstroBruce 03-03-2021 06:02 PM
Flojet VFLO 5.0
Jkreis 03-08-2021 08:04 AM
I just experienced the same issue. Turned off city water, filled the fresh water tank and used the water pump for 3-4 mins. shut it off, then did the same several times. This fixed my issue. Good luck
