Replacing glass on 1965 Airstream Tradewind 24'
I am planning on replacing two windows on my 1965 Airstream Tradewind 24'. Can i just replace with regular glass and then seal it with silicone?
I currently have shattered glass removed but it has a thin black strip on there. I am guessing that is an adhesive to bind glass to frame? Thank you. T |
T, you should get tempered glass. On our 66, the 1/8” tempered glass slid into a top bar. I had to run a drill bit perpendicular to the bar in the slot to enlarge it slightly to receive the glass. The black stuff was glazing tape used for typical framed windows. Good luck
Bubba, I had read that trailers before 66 used regular glass but was really unsure. Did you think Tempered glass would work for either 65 and 66 trailers? I am very inexperienced and am learning as i go. Did you just have a glass company cut the glass for you then?
I got most of the silicone out of the tracks on the window frame and it seems straight forward but......... Thanks.. T |
65 are flat glass windows 1/8 tempered, tinted if you want. Buy anywhere. Add glazing tape.
66 (67 and 68) are curved Corning glass still made by Airstream and sold by VTS. |
As Hittenstiehl pointed out, the street and curb side operable windows of the 66, 67 and 68 years had the chemical treated curved windows. The ones I had to replace were the front, rear and an inoperable one forward of the door which were all flat panes. I actually had two different glass suppliers I used for both our trailers. So yes, just order from a local glass shop. I think it is important for safety and durability to replace any flat pane with tempered on any year model.
